Old 08-30-2014, 10:26 PM
The 250 pistons can be sourced significantly cheaper than the 300s. Another reason I like the smaller capacity.
Old 09-02-2014, 12:31 PM
stian stian is offline
pssst. Nothing beats cubic inches.
Ive sent a order to Motocrosscenter 5 days ago. Havent received answer yet. Pretty terrible service, to be honest.
07` EC300SM. 09` KTM 250EXC. 70`CB350
Old 09-02-2014, 06:38 PM
john r b's Avatar
john r b john r b is offline
Perhaps their on Holiday.?
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
Old 09-03-2014, 12:42 PM
New piston is in. Did put the new rings in barrel without piston, ringgap is 0.20-0,25. I know recomended is 0,315 or something.
well, did put the piston it. Runs sweet.
Old 11-28-2014, 05:30 AM
spooly's Avatar
spooly spooly is offline
will someone confirm that mine is a B size???
Old 11-28-2014, 05:43 AM
Jim Cook's Avatar
Jim Cook Jim Cook is offline
Thumbs up
It certainly started out as a B. I would measure the diameter a few places along the bore to check wear. If you don't have a measuring device, use a piston ring and measure the bore and compare end gap differences at different heights.
It doesn't take a lot of wear to be able to use a C piston in a B cylinder. The difference in diameter between one piston and the other is only 1/100mm; and they use the same rings.
I often go to the next size piston to accommodate wear (keep the tolerances tight and reduce piston skirt slap).
When I have a cylinder repaired/re-coated, I normally send an A piston for them to match the new bore to; giving me a head start on ring wear.
Happy Thanksgiving and Good Riding!
Jim
Jim Cook
Smackover Racing
Team LAGNAF
'06 Gas Gas DE300
2004 Gas Gas TXT300 Pro
'94 Husaberg FE350
'86 Yamaha IT200
'86 Honda TRL200 Reflex
Let's go riding!
Old 11-28-2014, 06:46 AM
spooly's Avatar
and I ordered the b size last night.
Piston size, A/B/C. How important? jdosher Enduro Engine - 2 stroke 5 01-28-2013 08:16 AM
What "size" piston without removing barrel Eugene Enduro Engine - 2 stroke 20 01-04-2012 10:55 AM
What size of piston? Todd5774 Enduro Engine - 2 stroke 3 10-24-2011 03:20 PM
no piston size stamped on cylinder? stainlesscycle Enduro Engine - 2 stroke 0 08-10-2011 06:44 AM
Cylinder measurement results below so which size piston? stay_upright Enduro Engine - 2 stroke 1 07-28-2009 12:43 AM
