Old 02-25-2019, 11:50 AM
5valve 5valve is offline
Default Crank bearings
Just received stator side crank bearing.
It is double rubber protected. I guess there is no need to remove rubber, as it is self lubricated.
Had bad experience using non oem, but quality branded C4 bearing on stator side. Crank had play in bearing from day 1. Cases and crank are not worn.
Will use regular branded C3 on clutch side, as previous showed no deterioration.
Just dont know if rubber protection should be left or not.
As I remember, only one side was protected, but dont know which, towards chamber or gearbox.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 02-25-2019, 12:13 PM
(F5) (F5) is online now
Pull em all out. Premix does the lube and no point shrouding it from any side. Seals are for wheels.
Old 02-25-2019, 03:20 PM
SS109 SS109 is offline
Yup! I concur!
Old 02-26-2019, 02:18 AM
Originally Posted by SS109 View Post
Yup! I concur!
Me too!!
Old 02-26-2019, 02:28 AM
RudolfHucker's Avatar
Is that the correct bearing?
I am really surprised that a manufacturer would supply a sealed bearing for use on a crank as I would expect the seal to melt and cause all kinds of problems in the combustion area.
Old 02-26-2019, 03:02 AM
Its oem gg ordered bearing.
When i removed original bearing, it had protection installed.
I guess if you get accidental debris like sand inside it does offer some protection.
But will remove.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 02-26-2019, 05:47 AM
Anders Anders is offline
GG used sealed bearings for some model years, at least in my son's '08 300. One bearing failed, and when I opened the engine, I found sealed bearings in both sides of the crank. I replaced them with open bearings and the engine has been running happily ever after.
Old 02-26-2019, 12:24 PM
Thumbs up
Enough said
EC 300 2008
EC 300 2018 GP
tenere 700
Old 02-26-2019, 03:27 PM
Originally Posted by 5valve View Post
Enough said
My 2010 ran on sealed bearing until I did the bottom end out of preventative maintenance at 260hrs. They had dried out a bit but weren't failing.. I put the new ones in with the seals removed.
Old 02-26-2019, 03:38 PM
Hmm, my '11 is now at 280 hours. I guess I better start collecting parts for a rebuild.
08 Crank Bearings PEB Enduro Engine - 2 stroke 17 12-04-2012 10:27 PM
Crank bearings Marki Enduro Engine - 2 stroke 2 12-29-2011 11:47 AM
Crank Bearings? GasGas Enduro Engine - 2 stroke 1 07-13-2008 03:24 PM
crank bearings steve Enduro Engine - 2 stroke 0 02-06-2008 02:51 PM
2008 Crank Bearings Skidad General Discussions & Announcements 46 01-03-2008 09:44 PM
