Old 03-07-2019, 09:07 AM
Rampart Rampart is offline
Default Is your forks react rebound like this? (video)
I mean like instant!
https://youtu.be/Zn8B1pM4K2Y
Because my don't
Old 03-07-2019, 07:49 PM
Huh? I can make mine do either.. Pretty pointless video. Little bit of spring energy on the return of a little push.. Basically just showing the influence/difference between a bleed hole wide open and closed.
Old 03-08-2019, 02:40 AM
i'm so sorry you watched that! But what pointless did you see in it?
Can you make same work of suspension on your gg? Because i can't... my fork do nothing from left to right full turns. GG EC300 2011. Is this my issue or it was deadborn from factory on my gg?
Old 03-08-2019, 10:23 AM
if yours doesnt react on rebound fully closed you have a technical issue. Between rebound fully open and closed there should be a pretty noticeable difference. Maybe not as much as in the video...
Old 03-08-2019, 11:01 AM
Yes, I understand that something is wrong with my suspension, the shock as well.
but the fork is fully serviced ... Looks like it should be given to a professional.
I just wanted to know how much this is a regular problem on gg. I have a friend with exactly the same model as me (EC300 2011) and his suspension also does not respond to rebound and compretion settings.
Old 03-08-2019, 04:44 PM
Do you mean the slowing of the rebound as the clicker is closed?
Most forks have a lot of free bleed built into them, which means at low speeds like bouncing on the bike doesn't show a lot of damping. You don't actually want too much low speed damping anyway or you end up packing. Returning from deep in the stroke after a substantial impact is where you'll see the stacks deflecting and damping occurring. I wouldn't worry about how your bike bounces, and tune to how it rides.
PS. If you 2011 has the 45mm Zokes it will probably have lots of free bleed in it's design too.
Rebound inner rod marzocchi 45 5valve Enduro Suspension 0 02-11-2015 01:49 PM
How to adust rebound mlbco Enduro Suspension 14 11-22-2011 01:21 PM
Help with Rebound 11 Zokes Tlineman Enduro Suspension 12 07-26-2011 04:34 PM
43mm WP rebound, help! rupecopp Enduro Suspension 2 01-03-2009 11:01 PM
Rebound adjustment on 04 & 05 MC and EC FFRDave Enduro Suspension 4 01-23-2008 10:25 AM
