2011 Ec200 Rear Brake Line + Swingarm
Has anyone else had an issue with their rear brake line rubbing against the swingarm to the point of having deep gashes in the swingarm? I filled the low spots with jb weld in the mean time, but i find it hard to believe that its supposed to do that.
Post some pics. I only had it rubbing against the engine but just loosened the banjo and turned it slightly, but I have the Hyde swing arm guards so the hose does not contact the swing arm at all on my bike
I have! Mines rubbed the swingarm and the engine casing. I did like Matt did and roatated the loop away from the case a bit, and just put a bit of tape under the cable on the swingarm. Its worn through too.. I guess while it shows signs of wear I don't consider it excessive. Bikes done 9000kms or more now (who knows.. trailtech shat itself).. It'll go a few more kms yet too.
I wish i would've taken pictures before I jb welded but to the left of the brake line holder closest to the engine was where it was dug in pretty bad, the rest of the spots were minor.
Rear Brake Line Cross-Ref? | rpav | Enduro Chassis & Body | 0 | 02-20-2013 07:44 PM |
Breaking rear brake line | Gower | Enduro Chassis & Body | 5 | 04-17-2012 06:59 AM |
rear brake line issue | skid jackson | Enduro Engine - 2 stroke | 1 | 08-16-2009 09:05 PM |
Rear brake line crossover? | ScottyR | General Discussions & Announcements | 2 | 07-04-2007 06:17 AM |
