Old 11-21-2022, 02:51 PM
5valve 5valve is offline
Default Aluminum particles all over the place 2018 300
During slow ride gearbox locked in 1st, then freed and worked flawlessly again.
I do hear some noise now with clutch disengaged and occasional, could even be, extreme chain like rattle sound.
By hand, everything is rock solid, no play, rotates freely, no broken case parts, at least on the outside.
Since currently not really up to tearing engine again, I'd flush it and clean all rotating parts, clutch etc.. Whats would be better, diesel or gasoline?
3rd pic shows really amateurish oil cutout from rekluse.
Only alu, no steel, checked by magnet.
Any experience with that?
EC 300 2008
EC 300 2018 GP
tenere 700
Old 11-21-2022, 05:21 PM
I can't comment on the aluminium particles, but my gut feeling is they shouldn't be there
with flushing i have used parafin / Kerosene to flush the gearbox after a deep swim. If you cant get that, i would rather go with diesel over gas, just because it is closer to being an oil - and you are less likely to set yourself on fire
2003 txt250 Pro
2013 Ossa 280i
Old 11-22-2022, 01:48 AM
Anders's Avatar
Anders Anders is offline
I'm with Swazi_Matt here, those particles should not be there
Perhapse something is rubbing inside the gearbox? Did you split the engine at some point? Sounds like e.g. a shim may have been misplaced.
I think a flushing will do just that; flush particles out. And then I would assume more particles will be produced until you fix the root cause.
EDIT:
Could it be the water pump impeller that's rubbing?
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 11-22-2022, 12:18 PM
(F5)'s Avatar
(F5) (F5) is offline
The gearbox locked and there's shrapnel everywhere and you want us to tell you it's ok to ignore it because it would be inconvenient?
Sure. Dave says; It's ok.
Start saving.
Wear armour for when it locks in 4th and the clutch doesn't save you.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 11-22-2022, 12:32 PM
SS109's Avatar
SS109 SS109 is online now
Time to find out for sure where those aluminum particles are coming from. Start disassembling until you find it.
WildAzzRacing YouTube channel
AZ State Parks OHV Ambassador
'11 EC250R
'98 KDX220
Old 11-22-2022, 01:42 PM
EDIT:
wouldn't the waterpump impellor rub on the water side, not engine side?
2003 txt250 Pro
2013 Ossa 280i
Old 11-22-2022, 03:49 PM
Anders's Avatar
Yes, I think you are right
Anders
1986 Duc Mille S2
etc
Old 11-25-2022, 09:17 AM
Engine was apart already 2 times, unrelated issue, main bearing failure.
Worked flawlessly for 30 hrs since.
Alu impeler is not damaged and cant enter gear/clutch.
Gearbox didnt get stuck, it seems like some foreign piece on the clutch side temporarily jammed under outer shift fork, freed instantly, and got ground all over the place.
No magnetic debris whatsovever.
I've inspected everything on the right side, and there is absolutely no damage or broken off parts from case, clutch basket etc. Checked clutch plate by plate..nothing unusual. @95 hrs like new.
Also, by my knowledge, the is no aluminum engine parts in the gearbox, except cases, so nothing should come loose, even alu washers are not present.
Flushed with gasoline today, will do some more, guessing 90% clean.
Might forgot sth in there that lasted 3 service intervals, time will tell.
EC 300 2008
EC 300 2018 GP
tenere 700
Old 11-25-2022, 09:19 PM
Zman's Avatar
Zman Zman is offline
Sounds like it had a piece of Aluminum debris in the trans which is not impossible. I have previously posted on a half dozen shim washers I found in the crankcase of our 2003 DE300. I believe they were in there from the factory.
Old 11-29-2022, 07:46 AM
Interesting find, when removed pressure plate from clutch gear. Anodization still in place over cavitated/worn/ bad cast surface, so it was like that from factory. Therefore this is not the culprit.
Now cleaned soon test.
EC 300 2008
EC 300 2018 GP
tenere 700
Best place to buy parts? DLap13 Enduro Engine - 2 stroke 6 09-01-2017 06:00 PM
GasGas in second Place hadfield4wd General Discussions & Announcements 3 05-03-2017 07:29 AM
Central PA place like HMT hadfield4wd NorthEast United States 1 04-04-2017 07:12 PM
Best place for OEM hardware? Koko General Discussions & Announcements 25 09-02-2012 11:02 AM
this may not be the correct place to ask, but... compmoto SouthEast United States 6 10-30-2010 02:10 PM
