Trusty adj Power valve
Trusty Adjustable Power valve in excellent condition. DOSE NOT FIT 200 MODELS!!! Fits 250-300cc up to 2014 models
'12 XC 200 TTX Sold '15 XC 250E Sale pending |
How much?
If Jak dont take Im interested
I have 2 of these they make them specific for 300 or 250 they are different 300 model does not fit on the 250 vice versa what did it come off
I just sent you a PM
Believe nothing, no matter where you read it or who has said it, not even if I have said it, unless it agrees with your own reason and your own common sense. [Buddha] |
Frankinberg, I have the detailed instructions from Trusty and on the Title it reads 250&300.
I have 2 trusty covers they both would only fit on my 300 tried them on my 250 the hole in the cover was not centered to the power valve shaft
Frankin, Yes this is the same experience i had putting this on the 200,everything bolted up beautifully. till putting the cover back on.
That would make sense. If all the power valve parts are the same on the 200 250 and 300 then the bigger bore would require the power valve parts to be pushed forward. Do you have a specific part number for the cover you have?
I responded to your PM, let me know if it went through this time.
Trusty Adjustable Power Valve | Kingtrevorton | Parts | 0 | 07-12-2014 09:18 PM |
Trusty power valve spring | moto9 | Enduro Engine - 2 stroke | 0 | 01-20-2014 01:45 PM |
Loss of power - suspect power valve | Jonny Halls | Enduro Engine - 2 stroke | 4 | 01-22-2013 09:56 AM |
Trusty power valve | gassergrant | Enduro Engine - 2 stroke | 1 | 09-24-2012 03:20 PM |
Trusty Adjustable Power Valve | Stevie | Enduro Engine - 2 stroke | 0 | 04-25-2011 04:10 AM |
