EC300 suddenly low on power but then returns back to normal
Hi,
I have a EC300 2008. With some strange enginge behavior. A couple of times i have experience suddenly power loss and a change in engine sound. First I thought i lost the silencer or the exhaus gasket. But they semes to be fine. Then i notice that it can go back to normal if I do a couple of more runs. You can listen to the sound i the clips on you tube. The first is very loud with bad power output. https://youtu.be/82lFPtz-hPY The other is normal power. https://youtu.be/NRMCXnJ5rKQ Between these clips i only did a 100m run. What do you think can cause this? Regards Mika |
Suddenly idle seems lean ... help!! | swazi_matt | Enduro Intake/Carburetion - 2 stroke | 18 | 06-20-2017 04:31 AM |
Bultaco Returns... | Rod Overstreet | All Other Bikes... | 12 | 06-23-2015 01:42 PM |
Bultaco returns | gasgasman | All Other Bikes... | 7 | 05-23-2014 07:10 AM |
EC250 suddenly won't rev on to pipe | Mattnzl | Enduro Engine - 2 stroke | 11 | 08-06-2012 02:55 AM |
Going back in time on an EC300..... | Keg | General Discussions & Announcements | 4 | 01-01-2011 03:18 AM |
