Old 05-16-2018, 09:42 AM
Middithegasgas Middithegasgas is offline
Exclamation Gasgas timing and ignition/ electrical
Hello gasgas peeps, shew have I learned a lot I have 2 fse450s a 04 sm and a 05 ec, one day I?m doing fat mile long wheelies, on new circle, get back down to 2 wheels, roll on that gas I hit absolutely about 80........ clink sound, then max crazy vibrations felt like going over rumbel strips constantly. Bike felt loaded and lugged but still had power, I was thinking it was the balance shaft some how so kept riding until it died! That was a bad idea!! Any how got my tow home, to find out the true problems, the stater bolts became loose and let that stater get sucked to the fly wheel, then started spinning and yea you know what happened, total inhalation lol. Well when I got into it I noticed it?s a 03 ignition flywheel, wire harnes, coil. I assume it?s been converted to the 03 from the 04 the block and frame are both 04. You can tell part numbers and diagrams from the fishe from gasgas they provide, life saver btw, come to find out that the 03 charging system is like 230-260$ and the 04-07 system is like 160 bucks that?s a big difference and why would any one want to take a 04 system and go backwards, this tells me some one had a parts bike or quad laying around. So I ordered a 03 charging system, and 04 left case , and duh the 2 are not compatible, the old chewed up case was a mq45041004 what is the same case as the mfs40011004 but the mq is quad numbers I believe, so some one used wild hp parts to put this super moto back together. What?s crazy also is I can get a 04 stater case but I can not get a 03400/450 case the only ones I have found can?t be sent to USA. So I have no choice to return the new 03 charging system and use a 04-07 that is compatible with my 04 stater case. So with all this being said I know the 04 voltage reg is the same as the 03 450 but the wire harness and coil systems totally different, do you think by chance I can run the 04 charging system on the 03 wire harness and it function?????????? State your answers and questions below because I?m going to try it anyways stay tuned !
Old 05-16-2018, 10:47 AM
Neil E. Neil E. is offline
Sorry, without some paragraphs, we can't figure out what you are talking about.
Old 05-16-2018, 10:50 AM
How you up load photos?
Old 05-16-2018, 11:55 AM
Post Reply Button
Manage Attachments
Submit Reply
Old 05-16-2018, 02:12 PM
(F5) (F5) is online now
I just bought the Electrix stator, made in UK. G146, bolted straight on to my 07.. Same as ktm, the do the G147 with higher output if you want better lights. Cheap for a Not made in China bit of kit.
Arrived, fitted and fired up last night. Not sure if that would help. I just couldn't read that. Try edit and hit enter a few times to break it up.
Old 05-18-2018, 06:30 PM
Thanks for the info on uploading the photos and stater upgrade, I?m doing this all by phone and uploads are not the best. I got a work shop manual, by what I can tell the charging system will all interchange with o3-06 with the correct stater cover. Also I know the o3 450 is the same as the 00-04 400s. The gasgas sm is vin makes it a 04 but has 03 harness loom and charger and cover. The 05 obviously different! But requires the 04 stater cover case not the 03 , cool aye?
File Type: jpg C8C3304C-BCA1-4A2E-A818-C69DCBCA7B85.jpg (132.2 KB, 12 views)
Old 05-21-2018, 05:17 PM
I've got electrexworld on mine too. Bolts straight on
2016 RM-Z450
Gasgas fse450 ignition problem Blechbuexe Enduro Engine 4 stroke (including EFI & Exhaust) 2 05-05-2017 03:45 PM
EC300 -2011 ignition timing FinGas Enduro Electrical & Wiring 9 04-10-2012 06:30 AM
04 300EC Ignition changed to DE Ignition Trail Blazer Enduro Engine - 2 stroke 0 01-08-2007 01:48 AM
