Old 03-27-2018, 08:30 PM
Halcon Halcon is offline
Default 2013 XC 300 throttle cable help
Hi All, I have a bit of mystery that I hope someone can help me solve. I have a 2013 XC 300, I snapped the throttle cable, so ordered a new one from my dealer, when it came (dealer is 1000 Kms away) it was not the same as my old one. The old one has a near 90 degree bend straight off the top of the carb to clear the gas tank, the new one has only about a 15-20 degree bend. I called the dealer back, he was not sure so ordered 2 more of what should have been the right part, when they arrived they were the same as the one he already sent, so he does not know what to do. If someone can shed some light on this or give me the correct part number I would really apprciate it, thank in advance.
Old 03-27-2018, 08:49 PM
barossi73's Avatar
Could be the difference between the older carb (as1)which has a "screw lid" and your later "squarish cap" type (as2).Both are 38mm pwk airstryker.Im not sure which year they changed...maybe '11/'12?
2013 ec200r
Old 03-27-2018, 11:03 PM
Not sure what is normal, I have an AS2.
Old 03-28-2018, 04:24 AM
Gasser Nate's Avatar
To make it even more confusing I have seen the same model bike come out with two or three different carburettors... as1/2 and even a 36mm..
Old 03-28-2018, 11:55 PM
Adrian200xc Adrian200xc is offline
15-20 degree is what my 2013 has. Have you tried putting it on? I had a lectron on it and that cable was straight. Ran just fine.
2018 XC300
2013 XC200
Old 03-29-2018, 09:13 AM
Thanks for the replies, yes I did it hits the bottom of the gas tank I seem to need the 90 bendmine was born with.
Old 03-29-2018, 02:37 PM
I use a motion pro one with no bend. Sure it touches the tank, but it doesn't cause any issues at all. Just make sure it's routed well any any movement when turning the bars should happen up around the head stem only.
Thread Tools
Display Modes
03 throttle cable gassergrant Enduro Chassis & Body 0 06-10-2014 04:34 PM
Throttle cable nato Enduro Chassis & Body 9 04-11-2014 03:37 AM
Throttle Cable steve Enduro Intake/Carburetion - 2 stroke 5 02-14-2009 02:39 PM
throttle cable steve Enduro Intake/Carburetion - 2 stroke 5 02-08-2009 06:17 AM
Throttle cable dave948 Enduro Intake/Carburetion - 2 stroke 7 10-10-2008 04:16 PM
