Old 04-26-2018, 06:52 PM
rvangeel rvangeel is offline
Default Need to find Inner cartridge bushings-48mm marzocchi’s
Does anyone have the part number or know where to get inner cartridge fork bushings for the 48mm dual chamber marzocchi’s
See attached pic.
I’ve ordered two different sizes from racetech with no luck. The last set I got look correct but measure 36.15mm when assembled and require a lot of force to assemble and do not slide nicely when assembled.
Old 04-27-2018, 02:47 AM
I've generally found that most bushings require filing on the open ends in order to fit correctly
2016 RM-Z450
Old 04-27-2018, 04:19 AM
Anders's Avatar
Anders Anders is offline
Perhaps you could make the new bush thinner by removing some material fom the inside?
Did you ask your favourite GG dealer? I have had success with sourcing Marzocchi parts from my importer, but that was a part that has a part number in the parts catalog. I see that this bush is in the drawing, but without a part number in my 2015 parts catalog.
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Old 04-27-2018, 11:18 AM
Wimpy525 Wimpy525 is offline
Matto Cycle can hook you up. He will be doing mine next week and has replaced them in the past.
Old 04-27-2018, 11:39 AM
rvktm rvktm is offline
think there the same as 48 mm kyb.the seals are.
skf do bush kits
Old 04-27-2018, 11:45 AM
bit like piston rings you need a gap . i do vintage suspension often have to shim the bushes
Old 04-27-2018, 05:18 PM
I have asked my local dealer but have not had much luck. He said he would look into it but have not heard anything back.
How would you recommend removing material from the inside? There is a small end gap already.
I’d like to make these work as I already have $$ invested and can’t return them.
If all else fails I’ll check with Matto.
Thanks guys.
Old 04-27-2018, 09:53 PM
bikesparky bikesparky is offline
Default Fork Bushes
Innteck does them. The link can help as a guide.
Should be able to find Innteck as they are US made.
http://www.jwtimports.com.au/downloa...ents-Guide.pdf
Old 04-28-2018, 06:20 AM
I need the bushings for the inner cartridge not the normal fork tube. The previous owner broke the fork bleeder and continued to ride which allowed dirt and moisture into the inner cartridge.
Old 04-28-2018, 05:47 PM
Find a Beta dealer and enquire there. I found they have pretty good access to the OEM Marzocchi parts. Be prepared to open the wallet.
PFP adjuster on 48mm Marzocchi’s rvangeel Enduro Suspension 2 03-18-2018 03:26 AM
Marzocchi 48 Cartridge Problem fixmare Enduro Suspension 30 09-11-2017 05:38 AM
Fork Oil Volume for 2013 Shiver 48mm Closed Cartridge scov Enduro Suspension 3 04-21-2013 02:04 AM
Sachs 48mm Bushings Jakobi Enduro Suspension 9 06-19-2012 07:18 PM
