Old 05-12-2018, 10:37 AM
VilluEST VilluEST is offline
I'm actually now thinking about to find someone who can machine the piston for me so I could use the 35x15x1 or even 35x15x1.5 since small KTMs use this size. Would be one time job to use alternative available bushes.
Old 05-12-2018, 12:29 PM
rvktm rvktm is offline
thanks mate think the 14 is the spring rate found a suspension site in germany that lists ics springs the softest thay do is 14 dont no what the std rate fitted to the mar 48s . iv found a slide bush 36 od 15 wide 1mm used on mar 35 and ktm 50 /65 forks skf do them under a tenner each . a good tip i got of beta rr fb is to use ktm /wp fork protector rings/ bush 2.50 each uk
Old 05-12-2018, 01:05 PM
i see your problem thinking hard ish plastic tube bored to a good fit on the bush then use a two or 3 leg stone hone or ball hone to take the .1 out or jubilee clip!!!! to hold the bush to hone good luck
Old 05-12-2018, 01:18 PM
the ics springs in your forks are the same as kyb showa 18.9 id 26 od 100 long ln 142 161 176 190 210 rate. rw told me that 014 017 had sorter softer ics springs
Thread Tools
Display Modes
PFP adjuster on 48mm Marzocchi’s rvangeel Enduro Suspension 2 03-18-2018 03:26 AM
Marzocchi 48 Cartridge Problem fixmare Enduro Suspension 30 09-11-2017 05:38 AM
Fork Oil Volume for 2013 Shiver 48mm Closed Cartridge scov Enduro Suspension 3 04-21-2013 02:04 AM
Sachs 48mm Bushings Jakobi Enduro Suspension 9 06-19-2012 07:18 PM
