Old 05-09-2018, 06:35 PM
gasman88 gasman88 is offline
It's got some cracks. I got the whole parts bike still outside. I have most things. engine is no good. The light has a little crack and was painted that way when I got it. I wasn't going to use it. Just wanted to test some things.
Old 05-10-2018, 07:43 AM
fred99999au fred99999au is offline
You want to see some of my IT200s. Bottom of the barrel had rust pits throughout ( I like to think they make it lighter with less drag on the piston skirt), tide marks on crank and tranny bearings etc, frame rust covered by powder coating.
Point being they dont make those plastics any more and may be worth more than scrap.
Old 05-10-2018, 06:55 PM
I got it all including the motor torn apart in a crate outside unfortunately. It's only missing the handle bars and carb. Tank actually is decent is so is plastics, frame, swinger, rims. ECT ECT. Motor is toast. Part of the case halves broke off inside that supports the kicker shaft. I was sheering those every other day. But it did run awesome at one time. I got that plastic boost bottle too. Probably going on the gas gas for an experiment
Old 05-17-2018, 08:57 PM
I did get this light to work. Used an off/on toggle switch. Now I ordered a new light and got a off/ low/ right toggle switch. It's a dual headlight so I can probably one run 1 light which is ok for now. It looks cool.
Not a Gasser, but you gotta see...... desertgasser300 Pictures & Videos 3 12-27-2011 05:42 AM
The Pro's Make It Look So Easy Rick Pictures & Videos 1 12-04-2011 10:49 PM
Gotta Love It Rick Pictures & Videos 1 05-04-2010 05:59 AM
Do they make FMF SST gasser250sm Enduro Engine - 2 stroke 1 12-26-2008 10:16 AM
If we make it... would you buy it? Steve@Motowest GasGas Member Polls 12 07-09-2008 01:15 AM
