Old 07-06-2017, 12:42 PM
Munch Munch is offline
Default gas gas ec 300 2015 blowing fuses!
Hi guys, problem started last week.
Bike would start first kick, great. It would run great but as soon as I let off throttle it would die and start great again, not a fueling issue. I put it down to electrics, tore everything apart and fixed it by finding my battery was unplugged (to do with ignition key not getting power when I let off the gas??)
Bike ran great. I ride approx 15 minutes, shuts off.
Next day I take a look at it turns out it is blowing the fuse above the black (earth?) wire. I changed it and it lasted another 15-20minutes but after that I've been changing it and it wouldn't last more than a couple of minutes at maximum per fuse.
I can't seem to find information on what exactly this fuse links to (there are 2). I have looked for split wires but can't find anything.
Old 07-06-2017, 05:26 PM
Have you probed to see what sort of voltage is coming out of the regulator?
Old 07-07-2017, 01:43 PM
Neil E. Neil E. is offline
Newer bikes have a DC powered CDI, so any battery trouble means your bike will not run properly.
Old 07-07-2017, 10:14 PM
tzsuzuki tzsuzuki is offline
Default Fuses
Munch, I had a similar problem that I chased for a year. I disconnected all the un necessary electrics, lights, key etc. problem seemed to go away. I recently re connected everything, problem returned. Turns out when I applied the front brake it shorted out 12 volts to ground and blew the fuse.
Anyway check that out, unplug the brake switches see if it makes a difference.
John Farrell
AMRA 8M
2015 GasGas XC300 race
fork seals keep blowing BillH Enduro Suspension 7 11-19-2015 07:18 PM
'05 EC300 Keeps blowing bulbs siaknijustin Enduro Electrical & Wiring 5 10-02-2014 07:07 PM
2013 EC250 blowing voltage regulators rubber Jonny Enduro Electrical & Wiring 20 05-28-2014 09:51 AM
EC-400 FSE - Identifying Fuses lukemillar Enduro Electrical & Wiring 4 07-08-2013 03:17 PM
Fuel Pump Fuse (A8) on GG450 blowing Crankin04 Enduro Engine 4 stroke (including EFI & Exhaust) 5 08-30-2010 10:41 AM
