Old 07-21-2017, 06:35 PM
CORSA CORSA is offline
Default Chain tension
How tight or slack do you keep your chain at and where do you like to measure at.
Old 07-22-2017, 03:33 AM
Nocams Nocams is offline
I lift the chain just behind the top of the slider for a 50-55mm gap.
Old 07-22-2017, 04:01 AM
poelinca's Avatar
poelinca poelinca is offline
For my '14 the manual says to put the bike on the side stand and measure at the end of the chain guide, slack should be between 35 and 60 mm.
'14 EC300
Old 07-22-2017, 04:01 PM
I noticed in the Manuel it says 30 to 60 I just thought 30-40 was to tight
Old 07-22-2017, 04:28 PM
Run it where you feel comfortable.
Other option is that next time you have the shock out, pop the linkage back together and run the swingarm through its stroke and take note of where the chain is tightest. Mark and measure in a specific area for your own records and you'll know what works best.
I just stick 3 fingers between the swingarm and slider at the rear. I find my chain is usually a bit on the slacker side.
Old 07-23-2017, 06:08 AM
RBrider's Avatar
RBrider RBrider is offline
Thumbs up
+ 1
That's with the bike on a shop stand.
RB
Old 07-23-2017, 10:06 PM
Thanks that's where I set it at
Old 07-24-2017, 05:54 AM
When its a bit slack you'll get a bit of chattering/chain slap when rolling on at small throttle openings in higher gears.. but I've never let that worry me. I'd rather be a bit loose than too tight.
Chain tension drn51 Enduro Chassis & Body 8 01-05-2013 12:14 PM
Chain tension 300ec Enduro Chassis & Body 5 10-11-2012 10:41 AM
Chain tension ? Link Enduro Chassis & Body 4 11-25-2007 06:24 AM
