Old 08-09-2017, 02:41 AM
dewenduro's Avatar
dewenduro dewenduro is offline
Default Rekluse Core Manual (RMS7000)
Picture gallery:
https://goo.gl/photos/Qn6i33wQSk4oXvhw5
Questions:
Does any one know
-what's difference between 178-002B & 178-002A clutch boss?
-what's thickess the new rekluse fibre plate?
-what's thickess the new OEM fibre plate?
-what aim is the steel SEEGER ring in the clutch boss?
Theory:
Core manual steel drive plate thickness (0.06") 7 piece & 1 piece (0.04)
Sum: 7x0.06+0.04=0.46" (11.68mm)
Fibre plate
I think Gasgas new OEM 2.8 mm.
Sum: 2.8x8=22.4 mm
Plates height: 22.4+11.68=34.08 mm
This is not so good, because pressure plate and clutch boss full closed distance is 34.08 mm
I think the 178-002B need thicker fibre plate than 2.8mm.
(sample Cr250 fibre plate 3mm)
or thicker start steel plate, or more steel plate.
Has anyone run into the same problem?
In picture gallery, my fibre plate thickness is 2.65mm
I can slove this problem, I'm only curious.
Thanks!
Old 08-09-2017, 04:25 PM
There are 8 friction plates in your stack and 7 steels so your calc is wrong.
How does the stack actually measure up? I've never played with a rekluse to give any decent advice in afraid, does it have a set of instructions you can post?
2016 RM-Z450
Old 08-10-2017, 03:24 AM
dewenduro's Avatar
My calc contains 8 steels. 7 piece 0.06" and 1 piece 0.04"
Rekluse stack start with 0.04" steel plate.
I read on forum, the new gas OEM friction plate thickness is 2.85-2.9.
This is my calc error...
The newer RMS H450 rekluse steel plate thickness is 0.065" not 0.060"
https://www.extracross.com/Motocross...Precision.html
Instructions :
https://goo.gl/photos/AhqNyo3E593sHN8K6
https://goo.gl/photos/4WERAMXQ3DG4hQYA7
Rekluse Core Manual gasgasman Enduro Product Reviews 4 11-06-2016 03:54 AM
Rekluse Core EXP 3.0 d251man Parts 5 10-03-2016 06:05 PM
Rekluse Core EXP 3.0 Weekend Warrior General Discussions & Announcements 5 09-10-2014 10:47 PM
rekluse core manual question?? nambo-trev Enduro Engine - 2 stroke 3 02-15-2014 06:12 PM
Rekluse core EXP 2.0 desertgasser300 Parts 5 07-01-2013 11:29 PM
