Old 09-08-2013, 12:47 AM
Pinittowinit Pinittowinit is offline
Default Mystery solved!! Must read!!!
I kinda pride myself at jetting so naturally when I got a 2010 ec300 a few weeks ago I started going threw it. First I adjusted the floats. And then the rest of the jetting. But for some reason the idle would hang a tad. Not a lean idle hang either. The carb was just bring very inconsistent no matter what. Even though the floats were set correctly it would dribble fuel at any angle more than the kickstand. So I used this trick. But it wouldn't seal all the time. That's when I noticed a few tiny pieces of clear plastic in the hole! It's clearly the plastic from the tank when the factory drills for the petcock! Problem solved. I also noticed the air screw was collecting dirt from fuel seeping out. So ill be replacing that too
http://www.youtube.com/watch?v=Kgog_Ng0-2Q&sns=em
Old 09-08-2013, 02:13 AM
Wait.. How would they plastic pieces get past the filter in the tank, unless They are pieces of the filter. I'm gonna take the tank off and pull the petcock and see what's going on
Old 09-08-2013, 07:35 AM
I think you'll find most of us run inline filters for this very reason
Glad its helped sort your issues out
Old 09-09-2013, 07:05 AM
Wimpy525 Wimpy525 is offline
Stock fuel filter comes apart, happend to me found the sam plastic. Put on a 90* in line fuel filter and problem solved.
Old 09-09-2013, 08:35 AM
twowheels's Avatar
There are a lot of GasGas tanks with the little filter flopping around in the bottom. It seems to be a 'not quite tight enough' fit on the fuel outlet pipe.
Steven Beane #275
afterhourscycle.com
Milky Tranny Fluid - my problem finally solved - may help someone DaveH Enduro Engine - 2 stroke 12 02-01-2014 10:55 AM
2004 ec300 sub frame "mystery" houndog Enduro Chassis & Body 11 01-03-2013 05:01 PM
Interesting read! desertgasser300 General Discussions & Announcements 11 06-28-2012 10:59 PM
I wanted a street legal 2 stroke. How I solved the problem Bobt250 General Discussions & Announcements 11 12-27-2010 02:50 PM
Mystery Bolt Killed my bike! gtsnowcrack Enduro Engine - 2 stroke 5 04-04-2007 03:41 PM
