Old 02-28-2019, 06:06 PM
(F5)'s Avatar
(F5) (F5) is offline
Ahh so you do have an in-line filter?
It is such a tight radius if you put a straight length in it it is easy for the line to crease inside strangling flow. It is hard to see and often inconsistent. An external spring as found on some roadbike can help.
'07 EC300 GG
'14 TXT250 GG
'22 765 Street Triple RS
'21 XTrainer
'69 Stinger T125 Suzuki
Old 03-11-2019, 09:56 AM
gandzo85 gandzo85 is offline
I had the same problem like that at theme subject. My problems start when I change carbon polini reeds on plastic boyesen reeds. Engine has no power at high RPM. My bike is gas ec 300 1999 or 2000. Needle N1ED on #1, MJ 185, PJ 42, fuele level was check and it is fine. Maybe the broblem is with power reeds, because when I take off air filter, I saw how mixture was take out from carburetor.
Do you have any ideas?
Ec 300 power valve Jonisaacson17 Enduro Engine - 2 stroke 11 07-18-2016 09:01 PM
Power Valve ? BigAl Enduro Engine - 2 stroke 4 01-05-2015 09:08 PM
Loss of power - suspect power valve Jonny Halls Enduro Engine - 2 stroke 4 01-22-2013 09:56 AM
power valve nut bonkeye Enduro Engine - 2 stroke 4 10-11-2012 06:40 PM
Power valve bens25au Enduro Engine - 2 stroke 2 02-09-2008 11:02 PM
