Old 02-21-2017, 07:40 AM
eff's Avatar
eff eff is offline
Looks like you need to find an 18" rear wheel now. Nice work.
Sent from my Pixel using Tapatalk
2004 GasGas DE250
Old 02-21-2017, 04:08 PM
Harry's Avatar
Harry Harry is offline
Nice work, I love these type of builds. More photos please.
Old 02-21-2017, 04:24 PM
Kbowen4 Kbowen4 is offline
Well today at work I ripped most of a fingernail off and then rolled my ankle quite hard shortly after. We'll see if I can wobble my way to the garage tomorrow for more pics because tonight I can barely walk
Old 02-21-2017, 04:40 PM
While I sit inside and stare ate the garage wishing my foot wasn't swollen here is a pic I took before cutting off the stock yz250f engine mounts. The pipe flange almost fits through there even though the mounts are holding it about 2 inches higher than it should be. One thing that I didn't mention is that I choose to cut the swingarm down to match the engine so that I don't damage my 300 block just in case the whole frame thing did not work out. So the spacer between the two swingarm roller bearings was taken out and I put the roller bearings closer together to make the gap between the swingarm about 12 millimeters Wider total.
Old 02-22-2017, 05:55 AM
CanGasser's Avatar
CanGasser CanGasser is offline
Did you get a chance to weigh this yet?
Current: 2007 GASGAS 300EC 2004 KTM 250 SX 2003 YZ450F
Old 03-02-2017, 01:22 PM
Default Still no weight yet
Well hopefully tonight I can get this rubber air boot seated into the air box properly tried to do it last night and thought about burning the air boot after fiddling with it for about an hour. Looks like I'm going to have to grind part of the frame off for the YZ250 air boot to fit around the shock area. I found a member of another Forum that did the same thing and it almost looked like it was like that from the Factory. Hopefully I can get the air boot sorted out tonight so that if the weather cooperates on Sunday I can take it for a real ride and report back and hopefully power wash it so I can get some nice shiny pictures up.
Old 03-02-2017, 04:26 PM
Neil E. Neil E. is offline
It's normal to have to heat the airbox boot with a heat gun to make it fit on a GasGas. It's probably even more necessary on your setup.
2011 EC250E
Old 03-04-2017, 01:31 PM
Well I got the yz250(not 250f) airboot to fit with some grinding to the frame. Made the Reed side carb boot just a hair longer using a car gas filler neck tube cut to the right size. Took it for a bit longer ride today. It feels like a yz250 with a better engine (go figure). The suspension is a little less plush than the gasser stuff but with much better bottoming resistance. Tomorrow I will be putting a few hours on it and cleaning it up for pictures after. Makes me wish I was a better rider to really utilize this beast.
On a side note I absolutely love the light clutch pull on these bikes.
Old 03-09-2017, 09:43 AM
Going to try to get a weight before the weekend is over
Old 03-09-2017, 06:11 PM
john r b's Avatar
john r b john r b is offline
Great work !!!
'12 XC 200 TTX Sold
'15 XC 250E Sale pending
(7) Mile/Swamp Creek Trail, NoCO Born2Ride Pictures & Videos 1 11-16-2016 05:42 AM
Nutrition for 100 mile race pscook Riding Techniques & Training 38 03-15-2013 12:13 PM
