Old 10-30-2018, 03:52 PM
Greatdane Greatdane is offline
Default G2 throttle tamer?
Anyone using a g2 throttle tamer? I have an 18 xc 250 and it seems no matter where i set my power valve, when the bike comes on the pipe it hits pretty aggresively. Raced in some super slick mud and even with the p.v. set at 1 turn out i had to be gentle when gassing it or there would be lots of wheelspin.
Old 10-30-2018, 04:38 PM
I have always loved the 250 engine, and always used the G2 quick pull.
Some of that is the nature of a 250. It has a slacker bottom end, yet makes similar peak hp.. that difference is made up for as the engine comes onto the pipe.
In super slick conditions everyone gets wheel spin. The best way around it is to upshift and carry momentum. That way you can use bigger throttle inputs, dampened with some clutch slipping, lower rpm which gives a softer delivery, and let the torque carry the bike. If momentum is lost it's hard to get going again, especially if fighting gravity!
In general I find that the clutch is what brings a 250 together. It allows you to utilise the bottom end power for smoothness, and then feed in the excitement as needed. I use the clutch to boost the revs into the band, yet control the hit to the ground. Bit like feathering as you take off vs just dumping the clutch.
Old 10-30-2018, 05:08 PM
webmaster's Avatar
Administrator
Are you still running stock n1ef needle?
With the stock jetting - which isn't good - it will typically 'clear out and hit' a tad...
Old 10-31-2018, 06:58 AM
Ive got the jetting sorted out. 175 m 40 pilot n3ch needle and have a rk tek cut head. My bike runs great and is a rocket. Decent torque too. Been riding 250 2 strokes for 30 years. Just seems like the transition from torqey to full on oower is a little abrupt. Not really complaining just thought maybe thr throttle tamer might do the trick.
Old 10-31-2018, 07:02 AM
Throw a Suzuki needle at it...
The N3 series are a dual taper that tend to transition pretty hard between bottom and top. The NE series have 3 tapers and supply a bit more fuel making for a more linear delivery.
Old 10-31-2018, 07:38 AM
I have a necj. Havent tried it yet. Would the pilot and or main need to be changed when switching?
Old 10-31-2018, 11:40 AM
webmaster's Avatar
Administrator
You typically go to a richer pilot, back off your idle setting...
Don't worry about targeting 1.5 turns out on air screw. I would opt for approx 2 1/4 turns out and a richer pilot with idle backed out.
Old 10-31-2018, 03:14 PM
So go to a 42 pilot or 45?
Old 10-31-2018, 03:52 PM
Probably the 45, however the J will likely be a touch lean in a 250. They suit the 300 a bit more.
If you are currently 40 N3CH#3 I'd be moving to 42 NEDW#2..
Old 10-31-2018, 04:00 PM
AZRickD AZRickD is offline
I put an EC pipe on my XC300.
Fairly mellow and linear.
Gas gas ec 200 throttle kiss161 Enduro Intake/Carburetion - 2 stroke 11 03-22-2016 02:23 PM
throttle jimjim "Wanted to Buy" & "Want To Trade" 3 05-03-2015 07:41 PM
Throttle Control iajim Enduro Intake/Carburetion - 2 stroke 2 11-07-2014 07:11 PM
Sticking Throttle SeanUK Enduro Chassis & Body 5 12-09-2008 01:27 PM
