'18 GP 300 Linkage - wtf
Prepping bike for season, first time linkage checkup.
Linkage movement hard, opened, nothing problematic, cleaned, regreased. Tested in vice, to check free movement - hard AF. Both connections. Linkage links are moving fine. What I realized is, that the large washer, being 0.9mm is too thick and it grinds into spacer. Bushings should be just a fraction longer. If remove only one of the two washers, spacer falls in too much, but free movement is obtained, if held in hand. If it were bolted with washer removed, it would be alu-alu grinding.
EC 300 2008 EC 300 2018 GP tenere 700 |
Looks like you're overthinking it.
Once the bolts are tightened, there's no movement between the spacer and the bushing. |
You dont understand.
Once tightened, and this is tested, it hardly moves, but should flow freely.
EC 300 2008 EC 300 2018 GP tenere 700 Last edited by 5valve; 03-06-2021 at 08:32 AM. |
Remove seal, remove one 0.9mm shim, reinstall seal. Spacers now sit closer together, but finally they rest on the bushing, which moves inside bearing.
Reinstalled, perfect fit, torqued, no free play, all the free movement regained.
Scorpion linkage to trade for stock linkage | rvangeel | "Wanted to Buy" & "Want To Trade" | 0 | 06-13-2019 08:25 PM |
11 linkage kit on a 13 | andykr87 | Enduro Chassis & Body | 2 | 01-14-2018 06:12 PM |
Linkage help please! | liv2day | Enduro Chassis & Body | 8 | 10-20-2017 12:06 PM |
Linkage | redrider7202 | General Discussions & Announcements | 12 | 05-18-2010 09:05 PM |
Linkage | redrider7202 | Enduro Suspension | 1 | 05-12-2010 05:34 AM |
