Old 04-22-2014, 06:52 PM
FastFast's Avatar
FastFast FastFast is offline
Default Experts, what jets for my bike?
I'm looking for some opinions and ideas to try out while jetting my bike. I know we have some really good tuners on here and I'd like to pick your brains a bit.
2013 XC300 Completely Stock and New.
50:1 w/ Amsoil Interceptor and fresh 93 octane
3000ft to 6000ft riding elevation
I have a JD Jetting Kit JDG002 at my disposal plus a few other jets in between.
Old 04-22-2014, 07:17 PM
thejackrabbit thejackrabbit is offline
make sure the power valve tension is adjusted before digging deeper too
Jack - western PA
2006 KTM 250 sx
2006 EC 200/ 11' style kit--GONE
2004 200 EXC
1997 KDX 220
2004 CRF 250X
1974 CL125
www.youtube.com/allthatstuff35 <---some gasgas videos here
Old 04-28-2014, 08:19 PM
FastFast's Avatar
I still can't tune out the blubbering just in the first few millimetres of throttle. Currently on a 38 pilot, red needle second clip from the top, and a 160 main. Air screw is out about 1.5 - 1.75 turns which seems to be ideal. I've tried all needle positions, 40 and 42 pilots, and all manor of air screw adjustment without success, usually worse actually. With the current settings this bike makes great power all over, excellent transition, torque, and response. No pinging, little smoke, starts right up, chokes great, decent idle too. I just can't get rid of the blubbering just off idle and it's driving me nuts. Bike is new, no motor mods.
Old 04-28-2014, 09:00 PM
djroggen's Avatar
djroggen djroggen is offline
160 seems lean try a 175 or 178.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Ortonville Minnesota
Old 04-28-2014, 09:02 PM
djroggen's Avatar
I have a 200 I bought, and couldn't figure out why it would fall on it's face when cracking the throttle from idle. I found a 145 in the main! Put a 172 and it fixed it for me.
2013 GasGas 300
2004 GasGas 200
2011 GasGas 300
Old 04-28-2014, 09:05 PM
Banned
Check float height also.
Old 04-28-2014, 11:31 PM
NUMBER ONE!! Set the float height..
JD Red is about the same diameter as a H in the OEM range of needles. You'll see most people are using J diameters on their 300s with good success. That puts you 2 steps leaner right in the 1/8th throttle range. Key reason why JD kits can get you close, but can't get you all the way.
The other consideration is the squish clearance. Many have chased their tales with jetting before having the head done. It really is the best bang for buck mod you can do. I believe that so much so that I had the head off my 2013 model after one short ride (which was only to see how it ran stock).
Old 04-29-2014, 09:42 AM
rosco's Avatar
rosco rosco is offline
That's close to the same elevations that we are running here. In the summer we run a 172 main, n3ch or n3cj needle in the 2nd clip position and a 40 pilot. In the winter we bump the main to a 175 and lower the clip to the 3rd position and bump the pilot to a 42. I have found that temperature and humidity have a lot more affect on jetting than elevation does.
Another thing that really plays a part on jetting is your air filter oil. I remember back 30 years ago when I was working at a local Honda dealer you could always tell the guys that were using the old Bel-Ray filter oil. Most guys just used motor oil back then so if you switched to the Bel-Ray filter oil you had to drop the jetting or else your bike ran like crap.
Rosco's Motorcycle and ATV
Rapid City, South Dakota
www.roscosmotorcycle.com
Old 04-29-2014, 10:08 AM
FastFast's Avatar
I'll start by setting the float level. What is the spec? Do I need to remove the air box to get the carb out, or is there enough flex in the rubber to pull it free?
Regarding the main jet suggestions, this problem I'm having is JUST off idle when rolling in slowly. Everywhere else in the throttle the bike is spot on. Isn't that fuel circuit controlled by the pilot and air screw? Or is there some overlap from all circuits which a main jet change could effect?
Old 04-29-2014, 04:55 PM
The overlap on the main is minimal in the area we are discussing.
Float level is stickied in this section of the forum - http://www.gasgasrider.org/forum/showthread.php?t=11886 - Set it around 8mm to compensate for the angle it leans forward at in the chasis. Stock should be 6.5mm
Best access to the needle and gets is by removing the tank, removing the cap and slide. You can then roll the carb to access pilots and mains with the clamps loosened. To remove the whole carb I find the process much easier to pull the silencer/pipe (either will work), loosen the upper subframe bolts, and undo the lower ones. Swing the whole deal up and out of the way. Much less tiring than wrestling in a confined space.
Rekluse experts please bones150 General Discussions & Announcements 17 05-23-2012 05:34 AM
Suspension experts please help mikemoto Enduro Suspension 22 03-08-2012 02:46 PM
Calling jetting experts! Todd5774 Enduro Intake/Carburetion - 2 stroke 19 02-23-2012 11:33 PM
what jets redrider7202 Enduro Intake/Carburetion - 2 stroke 2 09-07-2010 10:23 AM
Marzocchi experts - help with 08' EC250. nick790 Enduro Suspension 1 05-09-2009 02:41 PM
