Old 10-15-2012, 06:56 PM
70455 70455 is offline
Default 1997 kx airbox onto 2001 xc250
The boot on my gas gas intake is hard and needs replacing. I have an airbox with good boot from a 1997 kx125. The only conflict in a boot swap is 1/2" of hole position difference in the hole on the flat.
Should i drill new hole in gg box or mate kx airbox to gg box rear section?
Old 10-15-2012, 08:06 PM
bowhunter007's Avatar
bowhunter007 bowhunter007 is offline
It can certainly be modded to work. If it were a KX250 box & boot...you could just install, and ride. I'd mate the KX airbox to the GG subframe. Save your original GG parts untill you aquire the correct piece that you need.
All healed up, and ready to burn some fat.
Old 10-15-2012, 08:15 PM
The kx airbox backhalf does not come up as high as the gg. Not sure if the fender covers it fully. Kx subframe going on as original is trashed. Need to grind away seat weld nuts from kx subframe.
Old 10-15-2012, 10:23 PM
So i went ahead and relocated two holes in gg airbox to allow kx boot and metal ring to work. The studs on the kx ring are longer so may need to be ground to keep from rubbing boot in radius. The foam gasket from kx does not grip like adhesive. I can oull boot out by hand in straight section.
What adhesive do you guys use to seal inner ring to the boot flange?
airbox door: 2001 v. 2005? motogroove Enduro Chassis & Body 2 03-06-2012 06:44 PM
1999 EC 250 Vs. 1997 Kx 250 Vs. 2001 YZ 125 Sebastian Enduro Other... 4 10-16-2011 08:34 PM
2000 XC250 CDI for a 2001 UK EC300 krazy Enduro Electrical & Wiring 1 09-14-2008 04:58 PM
