Old 11-03-2017, 04:40 PM
Blakelpd5 Blakelpd5 is offline
Default 2014 XC250 rear wheel bearings
I am finding so many different options. Some lots have 3 bearings, some have two, all are different sizes. I believe 13-14 share the same bearings but no other years?
Does anyone have a solid answer on what I need? Sizes or part numbers?
Old 11-03-2017, 05:53 PM
PFD023 PFD023 is offline
Here's your answer.....http://partsfinder.onlinemicrofiche....20REAR%20WHEEL
Take the bearing numbers and do yourself a favour....buy quality Japanese bearings....NSK, NTN, KYB. Any shop selling Japanese bearings will be able to match the bearing based on the above parts fiche.
Old 11-04-2017, 01:22 PM
hamilton's Avatar
hamilton hamilton is offline
03-15 rear are all the same wheel bearings, 3 bearings 6004x2 6005x1
You can go cheap or better quality, I go cheap in the winter slop.
https://www.ebay.com/itm/New-Connect...53.m1438.l2649
https://www.gasgaspartsguy.com/WHEEL...talogId=-15678
careful you don't damage the step washer and alum spacer between bearings.
15 GASGAS EC 250
19 Sherco SE 125R
Old 11-05-2017, 09:23 PM
Zman's Avatar
Zman Zman is offline
To get longer bearing life, I use one of these grease gun needles to fill the bearing with marine grease. If you are careful you an slip the point under the seal by the inner race. I arrange the bearing so that seal is located on the inside of the hub.
https://www.ebay.com/p/Plews-05-037-...d=282444820630
Rear wheel bearings Wes32 Trials Chassis & Body 1 10-23-2016 10:49 PM
Rear wheel bearings on 03 kendunn Enduro Chassis & Body 8 01-06-2011 05:43 PM
Rear Wheel Bearing 2001 XC250 thomasbyrd Enduro Chassis & Body 0 10-04-2009 02:04 PM
Rear Wheel Bearings cladoo Enduro Chassis & Body 2 11-18-2008 10:14 AM
rear wheel bearings smithys ec250 United Kingdom 3 04-23-2008 04:01 PM
