Old 06-17-2012, 10:09 AM
savage sausage's Avatar
savage sausage savage sausage is offline
Default new air filter
just got a new twin air filter
am I spraying the oil inside & out ??
or just on the outside
thanks
Old 06-17-2012, 10:24 AM
5 views and no answers??
Old 06-17-2012, 11:30 AM
Idahocharley Idahocharley is offline
You want to coat it both inside and outside. I spray or pour oil on the inside and then massage it into the outside foam layer. Both layers should be fully colored with your favorite brand of foam filter oil.
Old 06-17-2012, 11:42 AM
Bought a new 2011 EC 300 SD late fall last year. Have maybe 15 hrs on the bike - the stock twin-air filter does not seem to really fit the cage all that well and I was concerned about the sealing interface. No matter how careful I installed it the sealing surface at the cage flange always involved some of the foam filtering material squished into the sealing surface.
I took a chance and bought a couple of DT-1 Foam Air Filters and I like the way they fit the cage much better. Anyone else with comments?
The DT-1-190-47NO filter does NOT go over the stock locating cage pins like the Twin-Air. It rides on the flange surface and has a nenoprene type of sealing surface adhered to the foam filter material. Although the filter is not pinned to the cage at the sealing edges it fits the mating flange much better in my opinion.
Just thought I would share this with everyone. Quality of DT filter looks to be good to me - I don't have any cleaning (stand-up to cleanings) information to share.
Old 06-17-2012, 01:34 PM
Thanks for the reply I appreciate that someone answered
as I thought inside and out
Old 06-17-2012, 03:32 PM
I've never used the aerosol filter oil, always use liquid and as stated apply a little at a time massaging it through until the whole filter has an even coating inside and out. I personally can't see a quick spray penetrating right into the foam.
Old 06-17-2012, 11:19 PM
lonetree lonetree is offline
+1...
no way would i rely on just aerosol spray oil. i dunk mine compleatly, then massage and wring out till excess is removed....
pre-filter 2stroker Enduro Intake/Carburetion - 2 stroke 6 04-26-2009 08:56 PM
Air filter anathema Enduro Engine 4 stroke (including EFI & Exhaust) 16 10-29-2008 07:54 PM
Which air filter for 07 EC Tom Zelko General Discussions & Announcements 9 06-29-2007 10:09 AM
FSE Oil Filter McGuiver Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-15-2007 08:49 AM
which air filter? speed addic Enduro Engine - 2 stroke 9 04-16-2007 07:21 AM
