Old 03-24-2018, 02:40 AM
Default O-RINGS Vs Oil seals in linkage
Just worth sharing. I last did my linkage and swingarm bearings nearly 4 years ago! Decided last night was the time to re grease, and the only bearing that was dry and shagged was the bottom shock bearing, the only one that had a 'proper' oil seal!
Long live o-rings!!!!
2016 RM-Z450
Old 03-24-2018, 07:29 AM
The O-rings work really well! I think they should be considered the "proper seal" :-)
Old 03-24-2018, 04:04 PM
I think the O-rings just add a bit more friction. You have a larger sealing surface, thus better seal at the cost of some resistance. Is the difference noticeable or does it hinder rear suspension performance?? Not that I can tell, and definitely works better than typical seals which have allowed crap into the bearing rollers...
Old 03-25-2018, 01:06 AM
And to top it all the orings in my linkage are from 2010
gasgas 450 ecf 2013 fork seals and dust seals alrighty Enduro Suspension 1 12-21-2016 02:46 PM
Just do rings?? 95jersey Enduro Engine - 2 stroke 10 10-06-2016 08:22 AM
Which way do the linkage and swing arm seals go in? VilluEST Enduro Suspension 7 03-18-2016 02:02 PM
Synery Seals SACHS 18mm shock seals Synergy-Seals Enduro Product Announcements 1 09-30-2011 03:33 PM
O-rings. Ud_luz Enduro Engine - 2 stroke 7 11-23-2009 06:14 PM
