  #11
Old 04-21-2017, 07:16 AM
If you have a stock bike you probably have a large squish measurement and you will pick up low and mid range power with little loss in top end if you use a thinner base gasket. If you have any ridge at the top of the cylinder you do not want to use a thinner base stack than what was in there previously because of possible ring snag at TDC.
While the factor stacks gaskets with few issues, I prefer the single gasket over a stack. Another option is to use some spray tack to glue together multiple gaskets.
Base gasket 2011 EC300 Quigs Enduro Engine - 2 stroke 10 10-04-2015 04:58 PM
wet base gasket thejackrabbit Enduro Engine - 2 stroke 6 02-09-2014 01:03 PM
Base Gasket re-use? motogroove Enduro Engine - 2 stroke 5 06-26-2011 07:56 PM
2010 300 Cylinder Base Gasket Question coopernicus Enduro Engine - 2 stroke 12 06-22-2011 09:31 PM
Base gasket Ud_luz Enduro Engine - 2 stroke 21 05-09-2008 07:38 AM
