Old 08-26-2019, 12:45 AM
Banditpowdercoat Banditpowdercoat is offline
Default Needle decoding question
So I am new to Keihin needles nomenclature, but what I have gathered, and please correct me if I am wrong, it's why Im posting,
GG OEM numbers are N1xx like my 98 N1EC.
Yamaha is N2xx
KTM is N3xx
Is N being the tattletale of OEM? But my q is the other 3. Mostly the number. Is it compatable to Keihin Taper letters? eg 1=A 2=B 3=C?
Also read GG N1xx are triple taper where the others are single?
Trying to decode my N1EC and some KTM, like N3EG to std Keihin numbers so I can order some. It's much more availible to me to get std Keihin numbers than OEM in most cases.
Is N1EC = AEC
and N3EG = CEG?
Old 08-26-2019, 10:02 PM
N-X-Y-Z (N3EJ) (NEDW) (NOZI) (N1EF)
N - OEM Needle identifier
X - Taper profile
Y - Clip position/length
Z - Diameter
The X/Y doesn't seem to share any common ground between needles. 3 is 2 taper needle. E is 3 taper, O is 3 taper, 1 is the stock GG needle also a 3 taper. I'm not sure if the tapers are the same between the NOZ/N1E. They do feel very similar. The Y part which indicates clip pos/length is also paired up with the taper profile (x) to form a needle with the same properties that allows for half clip adjustments. Exmaples N3Ex/N3Cx, NEDx/NECx. I have a feeling NOZx/N1Ex is the exception and are half clip different using the same taper.
Z is the needle diameter of the straight section of the needle. It covers idle to 1/8-1/4 depending on the needles taper profile. Sizes range from:
Nxxx needle diameters
D=2.685mm
E=2.695mm (JD Blue)
F=2.705mm
G= 2.715
H= 2.725
W/I=2.735 (JD Red)
J= 2.745
K=2.755
Suzuki come stock with the NExx needles. Ktm use NOZx or N8xx (same taper profile as the N3xx). TM, Sherco, Beta all share needles too, so I don't know if anyone really 'owns' anything.
All these needles are the same 2 taper profile, with varying lengths:
In 1/2 clip variations from leanest to richest they are...
N89x=leanest
N3Cx
N3Ex
N8Rx
N2Zx
N4Dx
N3Vx
N4Ax
N6Mx=richest
They share no similarities with Keihin/Sudco needles. You'll be able to cross reference the diameter and that is it. Keihin needles are a single taper. The angle of that taper is part of their naming.
Old 08-27-2019, 12:20 AM
barossi73's Avatar
Am i the only one wondering...does that much needle knowledge come at the price of a pile of toasted pistons/bores?
2013 ec200r
Old 08-27-2019, 08:58 AM
jhendr3702's Avatar
jakobi has a slight jetting problem....
Old 08-27-2019, 11:40 AM
Davehuge's Avatar
Davehuge Davehuge is offline
That's why it's always better/safer to start RICH and move step by step LEANER.
All the best, Dave.
Old 08-27-2019, 08:29 PM
barossi73's Avatar
Lol he may indeed have a slight jetting problem,but that is great for us in here!!
(Plus-every tweak must be thoroughly tested,and the merits discussed over a cold one or two)
2013 ec200r
Old 08-28-2019, 01:30 AM
Problem
Affliction
Calling
These are all but words we throw around trying to explain the rich tapestry of life. But what really counts is finding a decent needle and, therefore, Enlightenment. And 3rd gear wheelies.
Old 08-30-2019, 01:00 AM
I do miss a "like button". Thanks Jakobi for taking the time to help others. Much appreciated.
mikuni jet needle chart decoding... stainlesscycle All Other Bikes... 0 06-21-2011 03:42 PM
needle question stainlesscycle Enduro Intake/Carburetion - 2 stroke 19 07-15-2010 09:08 AM
Needle Question biggstr6 General Discussions & Announcements 2 04-30-2010 04:12 PM
vin#decoding cowboy General Discussions & Announcements 6 11-01-2009 06:47 PM
Needle question? JoshP Enduro Intake/Carburetion - 2 stroke 8 03-22-2007 10:10 PM
