Go Back   Rieju & GasGas Legacy Riders Club Forum > Classified Advertisements > Parts
Parts New/Used Components and All Bike Part Outs
Old 11-18-2014, 11:35 PM
crazycooter crazycooter is offline
Default GG Wild Quad New Old Stock Parts update!!!
Hello, Here is a current list (with pictures) of new in the package, factory original GasGas quad parts that I have. Let me know what you are interested in and I will get you a good price. I have a commercial shipping account with very reasonable rates.
I will be posting these on Ebay soon.
Thanks
Link to pictures:
http://s178.photobucket.com/user/cra...S%20GG%20Parts
Link to GasGas manuals for part number check:
http://www.gasgasmotos.es/en/manuals.html
Note: Older GasGas parts manuals have been known to have an occasional mistake or two when it comes to part numbers. Also some part numbers have been updated with new numbers and that may not be reflected in the parts manual, not to mention the English descriptions are not always the best. Most of these chassis parts should work for all of the quads made but it is up to you to do the necessary due diligence to ensure you are ordering the right part. I may be able to help with some of your questions.
Thanks
Qty Part Number Description
3 BQ300218052 REAR AXLE BEARING SPACER
3 BQ300218022 AXLE ECCENTRIC
5 BQ300318033CT SPROCKET DISC CARRIER
2 BQ300218057 REAR AXLE SEALS
1 BQ300432000 RADIATOR
1 BQ300218020 REAR AXLE
1 BQ300220032 FRONT HEADLIGHT COVER
2 BQ300214402 RT A-ARM LOWER
2 BQ450314402 RT A-ARM LOWER
1 BQ300214401 LF A-ARM UPPER
6 BQ300222131 CALIPER PIN
3 BQ300210016 BRAKE FLUID RESIVOR
6 BQ300218046 REAR WHEEL HUB NUT
6 BQ300210156 SEAT BASE RUBBER
10 BQ300210155 SEAT TO FRAME HOLDING RUBBER
2 BQ300214063 FRONT SPINDLE. AXIS STEERING UPRIGHT
1 BQ300232035 FAN COVER
1 BQ300222120 REAR BRAKE DISC CALIPER SUPPORT
6 BQ300218050 AXLE BEARING
4 BQ300218065 ECCENTRIC O?RING
5 BQ300222125 REAR BRAKE O?RING
1 BQ300222054 REAR BRAKE DISC SUPPORT
6 BQ300218021 REAR AXLE NUT SPACER
5 BQ300218041 REAR AXLE CIRCLIP
2 BQ300214700 TIE ROD, STEERING BAR
2 BQ300518027 REAR WHEEL HUB
2 BQ300212008 SWINGARM SHAFT
2 BQ300212007 SHORT SWINGARM BUSHING
1 BQ300332015 RADIATOR SUPPORT SET
41 BQ300222065 FRONT BRAKE PADS
Old 06-02-2016, 03:07 PM
Anybody need anything? Thanks
Old 01-18-2017, 12:23 PM
austrias2 austrias2 is offline
Smile
Hello
i need
Bq300220032 from wild hp!
Do you have it?
How much?
Where are you coming from?
Best Regards Christoph
Old 01-22-2017, 10:53 PM
Hello, sorry that part has sold.
Thanks
Old 01-23-2017, 09:34 PM
jimjim jimjim is offline
Originally Posted by austrias2 View Post
Hello
i need
Do you have it?
How much?
If you don't need a light a hood from a Suzuki z400 will fit
Old 05-13-2017, 08:55 AM
86twrturbo 86twrturbo is offline
Hi do you still have BQ300218033 sprocket carrier ?
Thanks
Bryan
Old 12-21-2017, 02:13 PM
Hello, Still lots of new old stock parts left as of Dec 21 2017!.....
quad engine parts for sale 450 wild 04 thumpercb Other GasGas Bikes/Quads 1 01-25-2022 10:53 AM
Tons of Gasgas Wild Quad New Old Stock Parts!!! crazycooter Parts 31 08-10-2018 06:05 PM
wild 450 quad dogsbody Other GasGas Bikes/Quads 2 07-02-2011 04:43 AM
piston 300 wild HP quad case-racing Enduro Engine - 2 stroke 2 02-03-2011 10:53 PM
450 wild quad service manual ? dogsbody Other GasGas Bikes/Quads 4 06-19-2009 05:44 PM
