Old 10-24-2018, 03:49 AM
Thompo Thompo is offline
Default Boring a 250 to 300?
Mornin,
I know the done thing to get a 300 barrel and head etc but they are hard to come by...
My 2011 250 with S3 cylinder has a bit of piston slap , piston only has 20hrs on it (was sold bike with "new piston" fitted, still has some of the black break in coating so seems legit) im guessing the barrel needs plating (no damage or worn areas) or a next size up piston. No idea on total hrs.
Is it possible to get the 250 bored and plated to take a 300 piston, are the castings the same?
Don't want to spend the money getting a size up piston, finding its still slapping and need plated anyway, when for a similar cost (+ Head) I could convert to a 300.
Cheers
Old 10-24-2018, 06:50 AM
I would say, not worth the trouble.
You would have to machine grooves in the cylinder for the head o-rings.
Old 10-24-2018, 07:30 AM
pscook's Avatar
pscook pscook is offline
You can get the cylinder measured and purchase the appropriate sized piston for the bore, assuming that the bore is round. I believe that there are four sizes of pistons available, so unless your bike was fitted with a C or D from new, then you should have room to drop in the right size piston. Again, assuming that your bore is round.
I think that the cylinder itself has an alpha marking on it indicating the original/OEM piston size, hopefully someone else here will point out where to look on the cylinder for the letter.
Phil
(New bike pending...)
Old 10-24-2018, 03:20 PM
There are multiple posts for big bore kits. You can overbore a 250 but as I recall you can not go all the way to a 300.
Old 10-25-2018, 03:29 AM
RudolfHucker's Avatar
Assuming that the barrel is not badly physically damaged, the normal route would be replating.
The UK leader in this is Langcourts in Weston super Mare. Give them a ring and see what they recommend. Normally you would buy a size A piston and send it with the barrel so that Langcourts can finish the bore to fit the piston and you are back to new. They can also repair damaged cylinders by welding up and machining before replating.
If you try to go from 250 to 300, you may also need a replacement CDI unit as well as the head. That assumes that the crank and rod are the same on both models. The whole thing is starting to spiral...
KTM used to do a 250 to 300 update kit and there were loads of parts in it and they were rarely successful.
Old 10-25-2018, 07:20 AM
You can run the 250 cdi on a 300 without issue.
A nice boring video and got quite stuck on my lonesome! motopsycho87 Pictures & Videos 5 11-17-2014 05:25 PM
New helmet technologies (long boring important read) Simmo737 General Discussions & Announcements 5 09-20-2014 10:12 PM
boring reed spacer question gassergrant Enduro Intake/Carburetion - 2 stroke 19 08-23-2012 01:10 PM
Is GasGas getting boring? Keg General Discussions & Announcements 5 03-20-2011 11:22 PM
