Old 01-05-2009, 05:11 PM
GasGas.ec300.Andy GasGas.ec300.Andy is offline
Default Strange Problem With My Gasgas Ec300 Am Ready To Burn It,
HI,
Guys now this is a strange problem i am having with my GasGas ec300 and wanted to see if anyone had some answers to it , I would like as many answers and ideas to try from diffrent people to run through before i burn it.
Right the problem i am having is that i can go out for about a hour or so with the lads and my bike will just cut out and wont start again not even with a tow off another bike ,I can get it back home into the shed put another plug in and it will start again.
I have had this bike for 2 years and never had a problem till now and its not a easy problem to pin point , I have used about 12 spark plugs upto now just to get out over a couple of weeks why has it started with such a wiered bloody issue.
Old 01-05-2009, 05:42 PM
jostby jostby is offline
If you have never had previous problems I suggest removing and cleaning the carb. If you are not comfortable doing this it would be a good idea to have help. It sounds like something is causing a slightly rich fuel condition... dirt in a passage or jet (which blocks the AIR needed to mix with the fuel). Only use compressed air to blow out passages after soaking in a cleaner or degreaser. Never use small wires or similar, they can actually cause the debris to plug the passage as you can't make the turns to push the debris out fully. Good luck!
'00 XC250 (mine)
LTS front and rear suspension, power valve cover, carb jet kit and rear chain glide, RB Designs head mod, BRP tall triple clamp, backyard foot-peg lowering conversion.
'04 EC250 (the kids)
(he can do his own mods haha!)
Old 01-05-2009, 07:23 PM
I might get the carb cleaned and setup again and see if that rules it out , Ive got to try everything one by one to get to the bottom of it.
I was think carb but with never having it off before thought i can not be that but dirt does get in.
Old 01-05-2009, 08:20 PM
eff's Avatar
eff eff is offline
BTW, what year?
I had a problem this last summer where my bike started running poorly and then at one point just crapped out. My bike had never done this before and I had just changed the jetting, but I had only moved the clip. It seems in the process I got some dirt in it. All I did to fix it was pull the carb and clean everything real well and returned the clip.
I second the clean the carb suggestion.
2004 GasGas DE250
Old 01-06-2009, 04:24 AM
Hamish Hamish is offline
does it run ok for the first 1/2 hr?
If so, forget the carby.
Sounds like either a stator or a cdi failing when it gets hot.
Get a can or freezer spray and spray the cdi when it does it next and see if it will go
2007 Gas Gas EC300
2005 CRF450X
2006 WR290F Wandas Bike
2007 CRF280X Rebeccas Bike
Old 01-06-2009, 01:01 PM
d2w's Avatar
d2w d2w is offline
I second an electrical problem; running fine then dying then firing-up fine after a (cool down) time smacks of something electical. A connection is opening due to heat, and then closing when cooled. A dirty carb won't clean itself.
Old 01-06-2009, 02:22 PM
easy enough to isolate the problem,,, change the plug right when it happens. Save the old plug and check it for spark when you get home and the bike cools off. Got spark? Electrical issue. No spark? Fouling plugs. When it dies don't be towing it to try to start it if you are going to check the plug later as you will foul the plug no matter what by doing that. Good luck.
'00 XC250 (mine)
Old 01-06-2009, 04:42 PM
Nick's Avatar
Nick Nick is offline
Had the exact thing happen on a KX and it was the CDI.
Old 01-06-2009, 05:35 PM
crem55 crem55 is offline
I had my 2000 gg 200 crap out on me in line for tech then after the gas stop and it was as simple as the new vent I put on my gas cap vent hose that was faulty
Old 01-06-2009, 06:03 PM
Does any of you guys have a cdi unit for a 2001 ec300 or no if any other bikes carry the same one and will i need the sensor on the fly wheel to match the new cdi.
Cheers for all the advice upto now.
Strange electrical problem GMP Enduro Electrical & Wiring 14 12-14-2010 08:25 AM
2006 EC300 problem fury1 Enduro Engine - 2 stroke 29 06-09-2009 05:40 PM
ec300 clutch problem dirtjunky_uk Enduro Engine - 2 stroke 13 02-27-2009 08:08 AM
06 EC300 - strange sound when over revved colinmc400 Enduro Intake/Carburetion - 2 stroke 5 05-02-2008 12:10 PM
Gear box problem 07 ec300 peterr Enduro Engine - 2 stroke 5 02-26-2007 01:07 AM
