Old 12-06-2009, 12:28 PM
GG27 GG27 is offline
Default 2010 carb question
Today I was riding with a EC 250 2010, really beautiful bike. I noticed that the 2010 models have a different carb. The particular bike was running perfect, really crisp with lots of power, rider had factory settings. was going up and down steep hills with no issues. What is this carb and what would be the major differences with the PWK?
EC250 2008 Skid plate, rad braces, Fork bleeders
Drz 400 Motard '03 (full spec)
Yz 250 '06, KTM exc 250 '05, exc 250 '04, exc 250 '02
WRF250 '02, KDX 220 '98, DT200R '93 all sold
Old 12-06-2009, 01:06 PM
MattR's Avatar
MattR MattR is offline
I didn't notice it before in the 2010 pics. I looked on the GasGas website and it is only called out as a 38mm carb (no model name). Here is a close-up of the new carb. It has a remote choke cable hooked up to a lever on the clutch perch (like a hot-start mini lever on 4T bikes). The top of the carb looks more rectangular than the older PWK style (round). I'm curious what model of carb this is. It's hard to read the logo, but is this a Mikuni TMX38 carb???
Matt
Current: 2009 Yamaha FZ1
Old 12-06-2009, 09:25 PM
IMHO it looks like the KEIHIN the KTM's have. I read that the racing versions have it since 2009. Nombatim's bike surely had it. What impressed me was the crisp response and the way it went down long steep hills without stalling!
Old 12-07-2009, 11:20 AM
Catarallus's Avatar
Catarallus Catarallus is offline
The carb is called Keihin PWK-S 38 AG. But i don't know the differents between the "old" and the "new" carb.
Old 12-07-2009, 02:19 PM
Ud_luz's Avatar
Ud_luz Ud_luz is offline
It's used on the KTM 150sx. The top is held on with allen bolts. I wouldn't mind trying one. I've been told the 150sx is virtually flawless carb wise.
04 Montesa 315R, 07 EC300, 21 KTM Erzberg 300, 21 Sherco 300 SEF-F, 23 KTM 690, 23 Rieju Mr Pro 300
Old 12-07-2009, 04:57 PM
RBD RBD is offline
I call it a short body PWK and they are 15 mm shorter from front to back of the carb spigots. They use all the same internal parts as the longer body PWK, slide float assy, bowl and jets, etc.
The short body PWK's also have a o-ring on the mixture screw, but the mixture screw is the same.
It is my opinion that they use a short body for room issues as there is not a lot of room for a carb, mono shock and a air box in a small package.
Ron
Old 12-08-2009, 12:06 AM
If the new carb is exactly the same internally as the old one, and there is no space problems why did they change it?
I think you can change the pilot jet on these carbs just by removing the 17mm drain plug as on my Yamaha YZ250, also the needle clip had a rubber gasket to reduce vibration.
Old 12-08-2009, 03:44 AM
iancp5's Avatar
iancp5 iancp5 is offline
Have they changed the reed block / spacer etc?
If they just allow the carb to be removed easier with the airbox in situ it's worth it. KTMs seem to have better fuelling, especially idle, thought maybe they had better tolerances on their squish?
Old 12-10-2009, 10:00 AM
300XCRider's Avatar
300XCRider 300XCRider is offline
Looks like the carb on my '09.
2009 GasGas EC300
2008 KTM 300XC - Sold
2004 KTM 450SX - Sold
Old 12-10-2009, 11:52 AM
RBD RBD is offline
The YZ carbs that I have worked on use a spring and bushing damper on the needle.
Yes, they did move the drain plug on the float bowl to allow excess to the pilot jet and main jet.
I wonder if gasgas will ever try the electronics on the carb like the YZ's and Kaw's?
Ron
Anyone fitted a carb? & starter clutch question sgoaty Enduro Engine 4 stroke (including EFI & Exhaust) 5 05-25-2011 05:02 AM
2010 GasGas Demo Day at Battle Creek MI May 22, 2010 twowheels General Discussions & Announcements 12 06-14-2010 06:29 AM
2010 question Silver General Discussions & Announcements 3 10-28-2009 09:27 AM
RB Carb Mod RBD Enduro Product Announcements 10 06-29-2008 07:57 PM
Carb Question Gas Stu Enduro Intake/Carburetion - 2 stroke 2 08-22-2007 04:33 AM
