Old 01-05-2020, 10:57 AM
GG221 GG221 is offline
Default Having problems with my bike.
2018 300 XC
I am having the following problems, not sure if they?re all related or separate issues, but started happening about the same time.
-bike is overheating very easily. I have changed head o-rings, T-stat bypass hose kit, 2.0 bar radiator cap, and I can see that the pump is working by looking in the top of the radiator. Still overheating.
-rattling noise in motor. It sounds like a jar of bolts is rattling around inside my motor, very loud and happens at idle and while riding. Something is loose somewhere? Hard to pinpoint where it?s coming from. Almost sounds like power valve but extremely loud.
-bike is bogging down when opening the throttle. Like it is sucking air somewhere. This may be a separate issue as it just started happening. I noticed it was doing it occasionally two ride ago in cold temps at open throttle. I changed jetting, one up on main and it was worse. Went back to original main and changed to one clip richer on needle and still worse. Went back to original jetting and now it is still doing it and it?s getting worse as time goes on. Keep in mind the jetting that I am at now is what I?ve been using for a long time throughout many temp ranges and it has been flawless. Getting a very severe bog at 1/3 throttle opening while riding.
I am going to start tearing everything apart. Ideas?
Old 01-05-2020, 12:17 PM
Moto7man Moto7man is online now
For starters, Do a leak down test. Pull off the pipe and look up the exhaust port to check the condition of the piston.
―Comedian Lewis Black
-Unknown Sardaukar
Old 01-05-2020, 01:24 PM
A mates 15 had pv adjuster come loose which made all sorts of noises plus crap running.
Old 01-07-2020, 11:41 AM
Anoter vote for the PV adjuster.
Take a closer look at the water pump, a view inside the rad means nothing. If seen bikes where the impeller came loose. The 2.0 bar rad cap is crap, it masks the problem rather than solve it...
Old 01-17-2020, 12:09 PM
I looked at my water pump impeller. It is fully intact and not loose.
I looked at my power valve adjuster, also it is not loose. I did notice some fluid inside and some white greasy stuff, not sure if this is normal or not? The fluid is red, my premix and my tranny oil are both red so not sure what it could be. Any other ideas?
File Type: jpg 49F2FA66-AF7B-482F-8788-53400EEC86B7.jpg (11.5 KB, 14 views)
File Type: jpg 19EA602F-4513-441C-9247-E43ADE328498.jpg (7.5 KB, 14 views)
Old 01-17-2020, 02:57 PM
My 18 gets fluid under that cap too, I also use atf and red premix but due to location I am assuming that is trans fluid
Old 01-17-2020, 03:55 PM
Same on both bikes in my garage, my buds GP 300 and my EC 300. I am pretty sure it's gear oil under the cap as all the parts of the PV actuation system are running in gear oil.
Old 01-21-2020, 09:24 PM
Could the noise problem be coming from the clutch? I remember one of the recall items was a washer somewhere in the clutch. The dealer I bought my bike from was far from capable so I?m wondering if this never was done and something came loose?
Old 01-21-2020, 11:54 PM
The clutch on these bikes are normally super noisy. Does the sound get quieter when you pull in the clutch lever?
New to the GasGas family with bike problems Astro South Africa 6 09-01-2013 12:23 AM
Getting trials bike clutch feel on an enduro bike? SpeedyManiac Enduro Chassis & Body 3 12-01-2010 02:11 PM
Rode new bike for 3 days, had more problems than fun gomi Enduro Engine 4 stroke (including EFI & Exhaust) 10 06-23-2009 02:26 PM
Lugging the bike and stalling - jetting, technique, wrong bike? stay_upright Riding Techniques & Training 21 04-18-2009 05:23 AM
