Old 11-20-2020, 01:05 AM
Anders's Avatar
Anders Anders is offline
Originally Posted by farmerj View Post
I can have the flywheel machined to remove material and create the larger gap.
My question is - doesn't a flywheel need to be balanced? Asked another way, if I remove material by making the existing cutout wider, won't it cause the fw to be out of balance?
And does it matter which side of the cutout (or gap) the excess material is removed from?
Thanks,
Jeff
yes, I would presume you would need to balance it by removing some material on the "other side" of the flywheel.
I'm quite certain it is important that you remove material from the correct side of the gap, as this gap controls the ignition timing (if I'm not mistaken).
Anders
1998 Bimota Supermono
1986 Duc Mille S2
1975 Guzzi sidecar hack
1961 Morini Corsaro 125
etc
Thread Tools
Display Modes
2k3 timing PEB Enduro Electrical & Wiring 2 06-26-2016 01:48 PM
Cam timing 450 FSE Just James Enduro Engine 4 stroke (including EFI & Exhaust) 6 07-18-2013 11:14 AM
PV timing? Fred1956 Enduro Engine - 2 stroke 3 04-14-2011 11:40 AM
Timing a 450? iancp5 Enduro Engine 4 stroke (including EFI & Exhaust) 4 05-28-2010 10:17 AM
For all who know Timing?? nwcycle General Discussions & Announcements 0 03-21-2009 11:25 AM
