Old 03-23-2009, 02:29 PM
ktmguy23 ktmguy23 is offline
Default Stock '07 bars
I am needing to add handguards to my '07 300 and need to know what kind of bars I have to order clamps for??? Thanks. They are Black and say GG on them.
Old 03-23-2009, 07:55 PM
rpduc rpduc is offline
I just put some of the new(?) Cycra Pro Bend CRM (center reach mount) handguards on my '05 MC 250.
http://store.cycraracing.com/ceremo.html
With that arrangement all you have to worry about is the whether they're 7/8" or 1-1/8" because the inner mounts clamp the bars right next to the clamps on the triple in the straight section of the bar. They look to be one of the cleanest and most rigid solutions out there in my opinion. We'll see...
I previously had Moose handguards with some tapered inner clamps for the pro taper type bars, but they always wanted to twist. Me thinks it's just not ideal mechanically to try to clamp anything to a tapered bar.
Ross
'05 MC 250
'91 Husky 610wxe
'04 Duc M800 R.I.P
'06 Duc S2r 1000 R.I.P
May be so... May be not so...
My Website
Old 03-24-2009, 07:52 AM
The Hebo bars have a taper angle very close to Pro Tapers. If your going to use a bar clamp type, the best I've used was the notched type (to clear the hoses) with the four M5 bolts. GoFasters used to have them (still do?). That said I agree with rpduc and prefer a different mount setup. That CRM mount looks interesting as long as there is enough straight section next to the bar mount to clamp on. If you have a submount setup or don't run a damper, the Bike Bonz mounts are very nice. I'm returning to a top mount, but having a custom plate made to use the damper with the Bike Bonz.
Stock HEbo Bars 1-1/8 ? biggstr6 General Discussions & Announcements 4 10-30-2009 07:04 AM
Bars Dingo Enduro Chassis & Body 8 09-12-2007 09:55 PM
