Old 08-07-2011, 10:20 AM
dirtjunky_uk dirtjunky_uk is offline
Default dogbone bearings shocking prices from gasgas uk so couple questions
hi all got my frame and swingarm back from powdercoat,rang gasgas uk for 2 bearings and 2 oil seals for where the dog bones connect to the swing arm,to be quoted a supidly high price of over 40 pounds for 2 bearings and 2 seals,i have managed to find a supplier for the bearings with the same code for 2 pounds odd each but no oil seals. they do however sell o rings in the same size could i use these instead of the original type seals thanks Adam.
Old 08-08-2011, 04:59 PM
wasp4banger wasp4banger is offline
Off Road Only in Wales do a linkage bearing kit for about ?50 which has all the bearings (maybe 8 or 9 of them), pins and proper oil seals, which I think work better than the 'o'ring seals.
Might be worth a try.
Gas Gas EC 300 '06
BMW F650
Old 08-08-2011, 05:04 PM
hi forgot about off road only thanks for that,i have already replaced the linkage bearings,so only needed the 2 for the bottom of the swingarm as i had to remove them before powdercoating,i'll try off road only for the correct seals as i brought the bearings today.
Old 08-08-2011, 10:08 PM
GMP's Avatar
GMP GMP is offline
IMO, the orings are better as they provide a tighter seal. I go a full season now without a linkage service, and its fine when I do tear it down. Buy them in bulk cheap and your set for a long time.
Old 08-09-2011, 03:42 PM
thanks for the info fitted them with the orings this morning, got the whole lot bearings and o rings for around 6 pound
Old 08-18-2011, 02:24 PM
Synergy-Seals Synergy-Seals is offline
Default knuckle bearings and seals
We will be releasing our own bushings and seals very soon. Please stay posted. Rob
www.synergyseals.com
209-938-9726
Being BOLD is BOLD! However, being confident is certain!
Ride with confidence again!
Made in the USA
2011 300 six days handle bar shocking matt_tidball Enduro Electrical & Wiring 3 02-02-2011 09:36 PM
Couple of Questions gascanuck General Discussions & Announcements 4 11-04-2009 09:01 AM
A couple of questions moto9 Enduro Chassis & Body 2 04-27-2009 12:27 AM
2009 GasGas Prices! Mark Berg - CPD General Discussions & Announcements 4 11-15-2008 09:23 PM
