Old 06-29-2020, 06:48 AM
Johanv Johanv is offline
Smile Spark Plug
Hi , I've a Gasgas300 2003 model 2stroke- replaced the plug for a 3rd time now in 3 weeks- bike starts easy and then just dies- take the plug out and put in a new one and starts first kick again- old plug not even 1 hour old but wet when taken out, is this due to fuel problem and what plug should it be? I put in a NGK BR8EG- is this the right plug? Also want to ask- the bike is strong from 3rd gear but 1st and 2nd gear not running smooth and strong but more of a spatter- is this fuel or reed valves? Thanks in advance
Old 06-29-2020, 08:11 AM
Anders Anders is online now
I would guess it's jetted a tad too fat, or that you ride it less aggressively (keep the motor running closer to idle / low throttle) than the previous owner. Or both. I experienced the same when I got the 2006 some years ago.
Read the jetting threads, check your jetting. Being a 2003 model, the carb may be worn, which does not help when you try to find the optimal jetting for your riding and conditions.
Old 06-29-2020, 12:19 PM
SS109 SS109 is offline
Plug is correct. The jetting is more than a tad off if you're killing plugs that fast. What is your current jetting? Have you checked the float level? If PWK carb, is the jet block gasket good?
Old 06-29-2020, 03:40 PM
plug is correct but if you're battling with jetting it will be much cheaper to test with a BR8ES
Old 06-29-2020, 06:55 PM
I would also check the float level as well if you have not done so.
Check to make sure you are not burning gear oil due to a leaking crank seal, which can cause plugs to foul and the bike to run like crap.
Old 07-01-2020, 03:38 AM
Default Spark Plug Issue
Hi, Thanks for the many replies- will have a look at the jetting etc.and when the problem is found will post my reply.
Old 07-12-2020, 08:22 AM
Current Jetting is a 38/170 - tried a BP6RES plug and it actually lasted for 2 weeks without issues, now this morning fouled the plug again after startup- bike started- ran for 3 secs and died, what is an easy way to check if the crank seal is blown?
Old 07-12-2020, 10:21 AM
This spark plug is far too hot. Changing the spark to a hotter one masks the problem but does not cure it.
Which oil (brand) and which mix are you running? Which fuel (brand and octane number) are you currently running?
Old 07-14-2020, 03:58 AM
Hi, running a 50:1 ratio on 95 unleaded fuel. Read a reply that over oiling an air filter can also result in killing the plug- had a look at my air filter and I think I was a bit eager on the air filter oil spray. When I removed the carb I also took out the reed block-its a boyesen block and the previous owner tried to modify another brand reed valves in there with some modification on the holding plate- the reed tips was also open- will replace them. What is the correct fuel? Should I rather use 93 unleaded?
Old 07-14-2020, 04:20 AM
I had a bike with a weak ignition that would kill plugs. Try a new plug cap, or better yet a coil and cap off another cdi ignition bike.
The stators themselves do fail but I'd expect more erratic behavior.
Spark plug eviljim Enduro Engine - 2 stroke 4 01-06-2013 02:35 PM
Spark Plug Gap savage sausage Enduro Engine - 2 stroke 3 04-15-2012 11:54 AM
Spark plug? Pepperami Enduro Engine - 2 stroke 3 06-28-2011 01:49 PM
Spark Plug Crankin04 Enduro Engine 4 stroke (including EFI & Exhaust) 18 03-02-2011 02:50 PM
Spark plug gasgas125sm08 Enduro Engine - 2 stroke 0 03-08-2010 09:42 AM
