Marzocchi 48mm CC Compression valve removal
Hi,
Wondering which brand everyones using? I know the size is the same as the 48mm KYB SSS however my racetech tool is a solid piece and can't accomodate the PFP adjuster, so here I am chasing another. Just curious which brand offers the most positive fit/clearance? Cheers Jake |
I bought mine from Ballards, it had the perfect indent from thr get go, 20 bucks I think.
Any idea what brand? I've emailed Dave at Suspension Matters. Hopefully he'll be able to scoot one out Monday for me
It's anodized red, no markings, machined with the indent. Sorry can't provide more info. Def from Ballards.
Just a service or a fiddle with the shims? |
I'm going riding in the morning! Still got the 2010 model ready to ride so no rush chasing parts.
Definitely need a post break in service, but I think I'll at least take the time to record what the stacks are and then go from there. Probably want to add some more rebound to them (piss off the bleed shim). I'm still tossing up if I want to up the spring rates or not. Pretty happy with the rear 5.4 rate. Might try and measure the rates on the fronts. |
Ended up ordering one of these. About the same price as I would have got the ballards one for. Blows paying almost as much in postage as you do for goods, but what can you do. I just hope they have enough relief to still positively lock into the fork cap. If not I'll look at having it machined out some more.
The inside isn't deep enough to accommodate the PFP adjuster. I had to order a custom machined piece on a local shop, problem solved .
Vindicator '11 EC 300R |
I checked the ballards website and theres looked very similar in depth also. I guess worst case scenario I'll drop it around an engineering shop and have them machine some out of it.
Thread Tools | |
Display Modes | |
Marzocchi 48mm CC Forks | SolidPerformance | Enduro Suspension | 334 | 01-08-2019 07:32 AM |
Marzocchi 48mm 2nd service | GMP | Enduro Suspension | 1 | 02-04-2013 04:16 PM |
48mm MRZ forks tool needed | Synergy-Seals | Enduro Suspension | 1 | 07-17-2012 12:41 PM |
48mm Marzocchi warning! | STM Suspension | Enduro Suspension | 17 | 03-22-2012 03:44 PM |
Marzocchi special tool for tearing down fork? | bergerhag | Enduro Suspension | 1 | 08-14-2007 08:42 PM |
