Old 02-06-2014, 12:14 AM
Bark3rd Bark3rd is offline
Default Cold weather and water in the radiator-quick answer please
I'm nice and warm in my bed right now wondering if I need to go the garage and tend to my bike. It is going to get into the single digits tonight which is unusual for our area. I popped a hose at the enduro last weekend and lost all the coolant-the sweep riders filled me up with bottled water to get back. I parked the bike when I got home and it still sits as I left it- straight water in the radiator. I actually went out a few min ago and topped it off with antifreeze but I'm worried about the water pump and head freezing since the antifreeze hasn't been circulated. What would you do? Starting it cause quite a commotion and wake my family and neighbors up.
1- not worry about it and go to sleep (preferred option)
2- turn on garage heater and worry about it later
3- drain all the coolant
4- start it- has to be done
5- let it freeze and crack up, race the 82 KX for the rest of the season. Go to sleep.
Old 02-06-2014, 12:22 AM
Well, I went with option one but failed to take into account I wouldn't be able to sleep worrying about my bike. Cranked up the old space heater. lolr
for future reference it would be good to know if engines like ours can be freeze damaged with straight water, not sure about the actual inner passages, etc.
Old 02-06-2014, 07:43 AM
pscook's Avatar
pscook pscook is offline
Your garage would have to be below freezing for quite a while to really cause a concern. If the inside of your garage is at 20 degrees F overnight (measured) then I would worry. If it's 20 F outside overnight, probably not so much. Another option is to hang a 60w drop light under the engine to provide some warmth, and for best results drape a blanket over the top of the bike with the light underneath.
I have left racebikes out overnight in freezing temps with just water or water wetter in the systems and haven't had any issues. It takes a fair amount of time at freezing (or below) to freeze the water. Not saying it wouldn't happen, but it might take longer than you think.
Phil
(New bike pending...)
Old 02-06-2014, 08:26 AM
Just un do the rad cap as it will allow any fee zing water to expanded out of that instead of out the head
03 ec300
honda cr500 94
Anders Anders is offline
I think the simple answer to this is "YES".
It may take som time, but in our area where it's below freezing point for months during winter any engine with straight water would be damaged.
Old 02-06-2014, 10:34 AM
I totally thought of this but wasn't convinced it would actually work in the system froze solid. I believe a small amount of ice would come out of the radiator cap hole but the ice could still expand enough in other parts of the engine, becoming solid at different times, to cause a problem.
Old 02-06-2014, 10:57 AM
Neil E. Neil E. is offline
..... the ice could still expand enough in other parts of the engine, becoming solid at different times, to cause a problem.
Correct, different rates of freezing will create internal ice dams. Don't chance it. Drain eveything if you don't have antifreeze on hand.
Old 02-06-2014, 01:16 PM
andoman's Avatar
andoman andoman is offline
It's moot now, but I would have pushed her just inside the front door.
Newest Spanish Girlfriend: 2011 300 Six Days
My Daughter is a U.S. Marine
cold weather gear best options / tricks britishgas General Discussions & Announcements 19 12-17-2013 10:08 PM
Cold weather jetting theexception_03 Enduro Intake/Carburetion - 2 stroke 1 04-16-2013 03:33 AM
jetting for cold weather.. stainlesscycle Enduro Intake/Carburetion - 2 stroke 1 10-01-2009 08:42 AM
cold weather jetting skid jackson Enduro Intake/Carburetion - 2 stroke 5 10-24-2008 08:10 AM
Cold weather - what to do?? 3hunerd Enduro Intake/Carburetion - 2 stroke 8 01-21-2008 11:50 PM
