Old 10-24-2013, 10:04 PM
Bandit9's Avatar
Bandit9 Bandit9 is offline
Really? I loved the AJP on my 05. Couldn't imagine swapping it out.
This Magura on my 12 is a little stiffer.
Blanco
Current ride: 2009 WR450
Previously owned: 12 Gas Gas XC300R, 06 WR450, 06 YZ250, 05 Gas Gas EC250, 05 KTM 450EXC, 02 KX250 w/EG310 kit, 03 YZ250F
Old 10-26-2013, 08:01 PM
Bandit9's Avatar
Happy to report front end issues are over. Took the caliper/MC apart and cleaned everything. Replaced fluid and bleed it. Spins free and the dragging has gone away. I also replaced the chain with a 114 link for the 50t sprocket. I estimate that the rear axle moved back about 15mm. Which is a lot. Man, that was what the bike needed. Finally the front end was planted. The front brake worked. I was able to lower my pegs. Much better position. I could stand up! Yeh!
Blanco
Old 10-26-2013, 08:06 PM
Bandit9's Avatar
Originally Posted by Fred1956 View Post
Also check for a bent rotor in the front as well, if the piston pushes back in cleanly/easily you shouldn't need a rebuild Take the caliper off and then spin the wheel to isolate the brakes from the bearings
& just my opinion-a 6.2 on the back is waaaay to big a spring, I saw you and you aren't that big i.e. I'm 195# and run a 5.4....
About the spring, I was finally able to set the sag today at 106mm. Unfortunately, I only had 10mm of static. So I think I actually need a 6.4!
Blanco
Old 10-30-2013, 01:51 PM
sevenfourate's Avatar
sevenfourate sevenfourate is offline
Originally Posted by StuJohnson View Post
I have bought rebuild kits on Ebay. Here in the US. I like to buy a lot of OEM parts from ServiceHonda.com. They stock most OEM (Japan Bikes) parts. The front and rear caliper are the same as what is on a YZ250/450 bike, just can't remember what years.
As for brake pins I would recommend finding the Stainless steel aftermarket ones as they don't rust or wear as fast. If I recall Zeta Racing makes them and so does Moose Racing. Plus the aftermarket ones eliminate that stupid little cap/cover and are a bolt head instead of the allen head type pin.
Sorry to dig up an OLD thread: But is a caliper rebuild kit from a YZ250 / 450 going to work on my 2006 EC 250 ????? (Front end im looking for - 2 piston Nissin caliper on right now).
Front brake was 'ok' - thats all. I flushed through new fluid and bled it - then noticed pads were a little low.
So ive just fitted new pads, cleaned up the pistons and caliper pins before applying some copper-slip and pushing everything backtogether again. And now the brake is binding quite badly.
Im guessing new piston seals would be my first point of call and at first glance theres not much available in the UK. So any other makes these calipers are fitted to, along with the year would widen my options !!!!
Or does anyone know the exact piston size - maybe this place in the UK can supply me with the seals: http://www.ebay.co.uk/itm/Honda-Kawa...item258096efdb
Regards Shuv - 2006 EC 250
Old 10-30-2013, 03:50 PM
Ok, been back out into the garage - took off the cap from the master-cyclinder to check fluid wasnt stupidy high (As i bled brake using new fluid; before i realised the pads were low).
And it was a touch high, so i dropped a little out, so its at the top of the sight-glass with bike sitting level.
Then took off caliper again, pumped brakes a few times till pads almost touched, then pushed pistons back in again (Pretty easily and with no fuss) and then re-attatched the caliper to fork leg. I checked the wheel spun fine without the caliper fitted and indeed it did
Pumped brakes a few times, to get pads out,and brakes still binding If i spin the wheel hard as i can by hand - i can barely get one revolution before it stops.
So: No leaks, new fluid, new pads, brakes working ok, but binding slightly ?
Im no brake expert at-all, but i can only think seals were ok where they were with old pads fitted, but having disturbed them in fitting fresh pads the piston / pistons are now sticking slightly.
Plausable ?
Old 10-30-2013, 04:16 PM
If the pistons have been exposed for some time due to having very little pad they could be a bit rough. Did you pop them right up and clean them well really well?
Old 10-30-2013, 04:24 PM
Pads were really low, with just a couple of mm left - so the pistons were well out.......
I got a few q-tips / cotton-buds and dipped in some WD40 and wiped and cleaned right around the sides of the piston, and cleaned up the face of the caliper where the piston enters / exits the caliper so it didnt drag any in crap that way either.
Bearing in mind it seemed ok before - id say i cleaned it up pretty good. Suppose i spent a good 20 minutes just cleaning.
Maybe like you say - i should get up early before work and remove the pads. Pop the pistons right out and double check all is smooth and well...........
Old 10-30-2013, 04:42 PM
It can't hurt. I'd probably give them a light touch up with some steel wool or wet and dry. Nothing abrasive enough that it will damage the actual piston, but that will remove any build up on it.
Old 10-30-2013, 05:30 PM
cbutler's Avatar
cbutler cbutler is offline
Clean and re grease the pines it slides on check that your disk is not bent.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 10-30-2013, 05:36 PM
Bandit9's Avatar
Originally Posted by cbutler View Post
Clean and re grease the pines it slides on check that your dick is not bent.
yikes! My is bent to the left!
LOL
Blanco
Front Wheel Bearings erniebearskin Enduro Chassis & Body 14 01-17-2014 09:15 AM
07 ec250 Front bearings different Mattnzl Enduro Suspension 3 03-12-2012 02:34 AM
Front bearings Hapnin Enduro Chassis & Body 3 07-02-2008 09:49 PM
Clutch dragging - replacement advice please stay_upright Enduro Engine - 2 stroke 11 05-17-2008 10:20 AM
front wheel bearings pizzaman Enduro Other... 4 10-31-2007 07:50 PM
