Old 10-30-2013, 06:21 PM
cbutler's Avatar
cbutler cbutler is offline
Originally Posted by Bandit9 View Post
yikes! My is bent to the left!
LOL
oops but that's funny
Try using your other hand.
02 EC 200
03 MC 250
88 VT 800
01 TXT 280
Old 10-31-2013, 01:04 PM
sevenfourate's Avatar
sevenfourate sevenfourate is offline
Well; I got up at 5am before work to sort this once and for all !
Removed caliper again, took pads out and fully exposed the pistons.
Cleaned them up good and proper and pushed them back in again......
Squeezed the lever a few times and only one piston came back out again. Had a good look and i could see bits of seal trying to come back out with the piston....
So, decided to remove both front and rear caliper while im doing the front, and have sent both off them off for refurbishment. (If you click the link uptop in orange - theres a huge article about what exactly they do) For this price its not worth me messing around with them myself - its easier and less painfull to do a couple of hours overtime at work ! Plus a 2 day turnaround means i'll be back riding next weekend. Just another problem that hopefully wont ever return !
http://www.powerhouseautomotive.co.u...yorkshire.html
Regards Shuv - 2006 EC 250
Old 11-05-2013, 09:37 PM
Bandit9's Avatar
Bandit9 Bandit9 is offline
Very unhappy to report my front brake problems are back and even worse now. The lever will barely move. The pistons in the caliper move freely. It has to be the MC, but we took it apart last weekend and it looked fine. No torn seals or anything. So I don't know. I'm rebuilding the MC, if that doesn't work, I will send it off somewhere.
Blanco
Current ride: 2009 WR450
Previously owned: 12 Gas Gas XC300R, 06 WR450, 06 YZ250, 05 Gas Gas EC250, 05 KTM 450EXC, 02 KX250 w/EG310 kit, 03 YZ250F
Old 11-05-2013, 09:49 PM
gasgasman's Avatar
There may be a restriction in the hose.
It may have delaminated internally, possibly impact damagefrom trail debris.
Old 11-05-2013, 10:02 PM
Bandit9's Avatar
We thought about that too, but we can back bleed fluid through the hose with no problem, it would squirt out in a nice little stream. So it appears the hose is fine.
We took the front brake MC off Paul's KTM and put it on my 300. Hoping to see if the MC was surely the problem. Hooked it all up and could not get the lever to firm up. We back bled it, front bled it, etc for 1.5 hrs before giving up.
I may send the whole assembly to my main GasGas guy in Houston. He is pretty good at fixing stuff I hear......
Blanco
Old 11-05-2013, 10:13 PM
gasgasman's Avatar
I may have my OEM caliper in the garage.
Lemme check.
Old 11-05-2013, 10:25 PM
gasgasman's Avatar
Gots it.
What cha wanna do?
Old 11-05-2013, 10:36 PM
Bandit9's Avatar
Sent PM. Thanks Girard.
Blanco
Front Wheel Bearings erniebearskin Enduro Chassis & Body 14 01-17-2014 09:15 AM
07 ec250 Front bearings different Mattnzl Enduro Suspension 3 03-12-2012 02:34 AM
Front bearings Hapnin Enduro Chassis & Body 3 07-02-2008 09:49 PM
Clutch dragging - replacement advice please stay_upright Enduro Engine - 2 stroke 11 05-17-2008 10:20 AM
front wheel bearings pizzaman Enduro Other... 4 10-31-2007 07:50 PM
