Old 08-11-2011, 03:53 PM
blanc blanc is offline
Default 2010 clutch install..?
hi all. I am installing my stock clutch after using a rekluse. Does anyone know the correct plate order and have a parts diagram?
Old 08-11-2011, 04:42 PM
Stoby's Avatar
Stoby Stoby is offline
Bronze Level Site Supporter
Not sure on 2010 but my manual shows 8 fibers 7 steel
Stoby
Old 08-12-2011, 04:32 AM
GasGas's Avatar
GasGas GasGas is offline
You should start with a fiber plate and end with a fiber plate. There should be a steel between each fiber plate. It's that simple.
2018 EC 300
Old 08-12-2011, 11:27 AM
Thanks, its more the location of the washers on the basket I am confused with, but looks like ill get there, ta for the advise
Old 08-12-2011, 12:44 PM
stainlesscycle's Avatar
if hub and basket are removed:
in this order
spacer washer(thrust washer)
2 needle bearings and sleeve
basket
hub
lock washer
nut
- both spacer washers should be the same thickness on 2010 i believe
then
plates
pressure plate
springs
cup washers
screws
if throwout bearing was removed:
(from inside out)
pushrod holder
throwout bearing
throwout washer
pressure plate
circlip
07 ec300
www.stainlesscycle.com
Rekluse exp install tips from the guys that know! nambo-trev Enduro Engine - 2 stroke 12 08-02-2011 10:19 PM
dyna ring install ? jhendr3702 General Discussions & Announcements 13 02-17-2011 03:29 PM
Scorpion Rad Frames-2010/11 EC-Install Pics JP4 Enduro Chassis & Body 4 02-07-2011 07:33 AM
top end install help!!!! rdbandkab Enduro Engine - 2 stroke 12 01-19-2007 04:20 PM
Tech Article : Rekluse Auto Clutch Install webmaster Enduro Engine - 2 stroke 0 07-24-2006 10:14 PM
