E-start and subframe kit, any experience out there?
Just was on another gnarly ride and had a few hills that really got me thinking about that friggin button. I know gofasters has the kit available with the subframe and Bendix for the estart and wiring, has anyone purchased it yet and added it? Was thinking about buying the whole issue
trevor |
When buying it, change the hole for thee bendix and put a bearing bushing or needle bearing in. Works much better and it is muchore reliable.
4 strokes are only good for power generators |
Good tip thx
trevor |
Thanks
2012 - XC 300 Racing Seattle, WA |
Has anyone ever modified the stock sub frame to accommodate the battery or a small lithium ion? If got access to good tig welders and what have you
trevor |
In the cover where the bendix is located is only a hole in the aluminum. I changed already an 3 e-starts and it works. 2 I made with bushings and 1 with a needle bearing.
Any photo's Elvis74??
Ok boys I bought the kit from mark today at gofasters, I'm going to mod my subframe to accommodate a lighter smaller shorai battery so I'll keep you all posted. Soon she will be an estart Nambo with a full rekluse manual clutch
trevor |
Has anyone tried making a bracket to strap a small shorai under the seat instead of taking up all that room in the airbox? I just picked up the shorai and it's tiny and fits quite perfect in the underside of the seat over top the airbox
trevor |
Well here is my first attempt, I have much better stainless crimped tye wraps so ill likely swap the big t&b ones out for that but it actually fits really snug so I doubt it'll move around a lot. Here's a few pics with some foam padding and anti vibe foam
trevor |
The RickyD Lectron Experience | AZRickD | Enduro Intake/Carburetion - 2 stroke | 70 | 06-27-2014 05:53 PM |
My experience with the Paleo Diet | AZRickD | Riding Techniques & Training | 48 | 04-29-2013 09:08 PM |
Anyone had experience with a Keihin PJ?? | Onespeed | Enduro Intake/Carburetion - 2 stroke | 1 | 04-09-2013 01:36 PM |
Any experience with Maxima BIO 2T? | jdosher | Enduro Engine - 2 stroke | 4 | 04-03-2011 12:05 PM |
