Old 06-09-2019, 02:42 PM
Ashmy19gasgas Ashmy19gasgas is offline
Default Max rev on start up
2019 gasgas ec300, just went to start her up after a ride out to put her away and shit myself has the second I pressed start button it was banging off limiter???
What the hell??
Any ideas or can anyone shed any light??
Cheers
Old 06-09-2019, 03:11 PM
Davehuge's Avatar
Davehuge Davehuge is online now
Simplest thing first...
Is the carb closing when you let go of the throttle? Normally you can hear a knock as the throttle slide snaps shut. Check the throttle cable is seated properly at the twist grip and on top of the carb.
Is there plenty of fuel? It will rev high if it's very lean, like if the carb float bowl was low on fuel. Try starting it with the fuel tap set to 'Reserve'.
What happens if you pull the choke on?
I'm sure it'll be something very simple...it's just a matter of finding it!
All the best, Dave.
Old 06-09-2019, 04:37 PM
My money will either be on the throttle cable has been pulled and unseated (can happen at either end; carb or throttle housing).. or some grit has gone down the intake and managed to bind the slide up. The first being much more likely!
Old 06-10-2019, 04:31 AM
Ok cheers boys I?ll get into it and have a look.
Thanks again 👍
Old 06-18-2019, 04:00 PM
Davehuge's Avatar
So what happened?
Did you find anything?
Hope you got it fixed.
Give us an update.
Need help. Where to start Wypipo Enduro Intake/Carburetion - 2 stroke 29 11-16-2018 05:00 PM
E start Travec200 "Wanted to Buy" & "Want To Trade" 3 03-30-2018 05:16 AM
E-Start Kit aflica General Discussions & Announcements 6 04-26-2013 05:57 PM
When did it all start? Anarchist General Discussions & Announcements 4 07-22-2006 05:49 PM
