Old 11-01-2009, 03:14 AM
Paul Somerville Paul Somerville is offline
Default help and advice please 400 output shaft
well since my last post i have now rebuilt the gearbox that gecided to friction weld 1st gear to the main shaft.
question is now how much end float should the output shaft have so if you have a 400 please could you help me by measureing the amount of float if you push and pull the engine sprocket how much does the shaft move in and out please
another question is do all 400's smoke on start up from cold, mine is fine after about 1 min warm up has new rings valve stem seals and good compression
can anyone tell me the function of the ball bearing and the spring that fits in an adjacent hole to the oil intake line is this some type of pressure release valve my spring looks like someone has stretched it i dont realy undersand what this ball does i have good oil cirulation (now) and am useing Rock oil TRM which is brilliant and has quietened the engine
haveing just read another thread can anyone please confirm how much engine oil should i be putting in my bike the manual i have says 1.8 lts i wonder if i am putting in too much oil?
all help will be appreciated as i am fast loosing the will to live with this bike (until i ride it next)
Waterpump shaft end play SpeedyManiac Enduro Engine - 2 stroke 1 04-08-2009 09:05 AM
swing arm shaft stuck whodat Enduro Chassis & Body 17 03-22-2009 07:53 AM
Kickstart shaft question GMP Enduro Engine - 2 stroke 6 02-22-2009 02:55 PM
300 De Stator Output? Boomhauer Enduro Electrical & Wiring 11 10-23-2007 09:07 AM
EC300 Stator Output Magellan Enduro Electrical & Wiring 10 07-21-2006 12:12 PM
