Old 02-19-2019, 03:25 AM
touringhornet touringhornet is offline
Default Rear wheel - Movement
Hi all,
I had some play i my rear wheel so fitted some new bearings which popped in and out with just a small tap, hardly any force at all, and i still have play in the wheel once on and tightened up! I fitted an 'all balls' bearing kit. Do you think the bearings are too loose maybe? wheel damaged over the years meaning they arent tight anymore?
Many Thanks,
Mike
Old 02-19-2019, 05:04 AM
Davehuge's Avatar
Davehuge Davehuge is offline
I had exactly the same problem with my well used 2004 EC300.
The correct fix is to replace the worn hub, of course this is quite expensive. If you're a serious/competition rider I guess you'd just go ahead and replace the hub or complete wheel. But if you're a serious/competition then you wouldn't be riding an old/worn bike like mine, you'd have a nice new bike, maybe a few years old at the most!
However, I fixed the problem by using a centre punch to 'peen' the bearing housings and fitted the bearings using Loctite 660 bearing fit.
I'm really pleased with how it worked, even after putting plenty of hours on the bike, I still can't feel any play in the wheel.
Yes, it's a bit of a bodge, but why not try it?
Detailed description of how to do it here...
https://www.grainews.ca/2014/12/10/h...-bearing-race/
Old 02-19-2019, 05:25 AM
Thanks very much! Let me try the Loctite method before anything more drastic. Its a weekend fun dirt bike at the end of the day, it doesn't have to be 100% pristine!
Edit: Just seen the link. Thanks for the extra info, really appreciate it. Thought it was new wheel time!
Old 02-19-2019, 03:21 PM
I've used that method in the past. Definitely works.. and if it fails again, then move onto the more expensive options of having the hub machined and sleeved or sourcing a new wheel.
Caliper movement welsh.Z.S. Enduro Chassis & Body 2 02-12-2019 12:03 AM
cross over for rear wheel dust seal/ wheel spacer jason tati Enduro Other... 3 07-16-2016 03:40 AM
PV shaft movement (video) 2010 ec300 justsam Enduro Engine - 2 stroke 6 04-04-2014 10:21 PM
Clutch Slave. How much movement? Marki Enduro Engine - 2 stroke 5 04-26-2013 12:38 PM
clutch slave movement ? jhendr3702 Enduro Engine - 2 stroke 0 03-16-2011 03:44 PM
