Old 11-29-2017, 06:28 AM
Marcão Marcão is offline
Default Loose frame nut...
Hi,
The M6 nut attached/pressed to the frame (sorry, don't know the right name for this kind of nut) where the upper pipe silentblock is fixed is loose (rotating on the frame), so it's not posible to torque it.
Any idea on how to fix it ?
kind regards,
Marc
'05 GAS GAS EC 250
'15 KTM EXC 350 F
'16 BMW R 1200 GS
'83 Honda CB 400
Old 11-29-2017, 06:44 AM
Anders Anders is online now
I presume this is a popnut. I guess the best fix would be to drill it out and insert a new one using proper tools.
Old 11-29-2017, 10:53 AM
Neil E. Neil E. is offline
You might try flushing around the nut with solvent (lacquer thinners) and then running a bead of red loctite around the nut. Rotate the nut to get the loctite to creep in (maybe oscillate back and forth too). If the loctite sets OK the nut should be held in place. It's worth a try before drilling it out. The key is to get it really clean before adding loctite.
Old 11-29-2017, 10:54 AM
That's the problem, Anders, to find the "popnut" and the proper tools down here where I live....
'05 GAS GAS EC 250
'15 KTM EXC 350 F
'16 BMW R 1200 GS
'83 Honda CB 400
Old 11-29-2017, 03:00 PM
Harry's Avatar
Harry Harry is offline
could you get it Tig welded to the frame?
Old 11-29-2017, 03:59 PM
No. The Riv nut is steel.
Old 11-29-2017, 05:38 PM
pscook's Avatar
pscook pscook is offline
Install Riv-nut Without Special Tool?????
Phil
(New bike pending...)
loose front wheel gump147 Enduro Chassis & Body 3 05-05-2015 12:40 PM
Ferderer at the Loose Moose! Rod Overstreet Off Road Racer's Corner 7 06-29-2014 11:23 PM
Loose Airscrew biggstr6 Enduro Intake/Carburetion - 2 stroke 6 07-29-2010 09:07 AM
loose bottom marzocchi cap noobi Enduro Suspension 2 06-06-2010 07:48 PM
Loose yellow wire in airbox stevethebrit Enduro Electrical & Wiring 2 09-30-2009 04:40 PM
