2011 EC300 Sachs stock spring rates??
I feel like I have searched the internet for hours, but I cant seem to come up with anything...
Does anyone know for certain what the stock spring rates are in a 2011 EC300 with sachs suspension front and rear??? Also for a 180lbs A-class rider who typically likes to run a little stiffer what would you recommend?? |
Did you have a look in the user manual?
http://www.gasgasmotos.es/en/manuals...11_en.pdf.html On page 35 it says: Suspension spring The standard spring is 5 SACHS; 5,2 ?HLINS I cannot find anything about fron fork spring rate, though. It's not listed in the parts manual either. But there, the spring rate of the Marzocchi fork is listed as "MUELLE K=4.2 / SPRING K=4.2"
I saw the rear spring that said 5, but I've also heard contradictory statements about that. I also didn't find anything at all in the manual about front spring rates.
You can measure the dimensions of the spring in order to determine the rate - and count number of coils. You can find calculators on-line...
I would do this regardless of what you find on the internet.... jeff
i seem to remember standard for spring being .42
@twowheels should be able to give an accurate answer
I'm trying to figure out what came stock in this bike. I already know the spring rates that are on my bike. The problem is I have super heavy springs in it for my fat butt. I just picked up a new 2018 so I'm trying to set this thing up close to stock or a 180lbs rider so I can keep it as a spare bike for my friends to ride.
2006 EC300 Forks and Spring rates | motopsycho87 | Enduro Suspension | 1 | 01-02-2014 05:16 PM |
Spring rates EC300 -05 | SGM | Enduro Suspension | 2 | 11-29-2012 11:55 AM |
07 ec 250-300 stock spring rates | widebear | Enduro Suspension | 4 | 04-29-2009 04:49 PM |
07 EC300 Stock Spring Rates? | cladoo | Enduro Suspension | 8 | 04-16-2007 03:43 AM |
Spring rates? | moto520 | General Discussions & Announcements | 2 | 02-10-2007 05:20 AM |
