Old 07-25-2010, 08:21 PM
dank's Avatar
dank dank is offline
Default learning to rebuild, alot sooner than i am ready for.
can somebody point me in the right direction to a link on how to do a top end rebuild on a kx100 with alot of pictures? my little sister froze her bike up solid on her second ride out with it. im also on my first bike so i have only the vague idea on how to do the rebuild, so help would be greatly appreciated.
03 ec250
hyde skidplate, cycra handguads, protaper contours
"what? it seemed like a good idea at the time!"
Old 07-26-2010, 12:07 AM
Gassey fan's Avatar
Gassey fan Gassey fan is offline
try www.gasgas.com-manuals-ec_shopmanual_06
chris
07 EC300
force rad guards, os pv cover,
Old 07-26-2010, 06:23 AM
dank's Avatar
link will not open for me... but thanks!
03 ec250
Old 07-26-2010, 06:37 AM
eff's Avatar
eff eff is offline
Just buy a shop manual for it or at least one of these.
http://www.themotorbookstore.com/kx80.html
2004 GasGas DE250
Old 07-26-2010, 03:51 PM
mountain thumper's Avatar
mountain thumper mountain thumper is offline
take out the plug and fill the jug full of oil, wait a week, drain it out and kick it with no plug for a while then put the plug back. its not the best advice(in fact it may be the worst), but it worked MANY times on our old(70ish) kawi 175
Le Crutan
98 ec250 sixdays, doma, eline pipe guard, zokes shivers from a cr250,fredette racing chain slider, protaper withbarkbusters (SOLD)
FOR THE SECOND TIME 07 EC300 polisport headlight, acerbis taillight ltr pv cover and case saver,trailtech endurance,120z fww, g2 throttle,xr chain puck:
Old 07-26-2010, 04:12 PM
dank's Avatar
im thinkin its a stuck piston or a ring that got messed up. im curious though, how would you drain the oil out? and what oil would you use? since it may be cheaper to get a new jug, your idea is rather intriguing, if only for discussion..
03 ec250
Old 07-26-2010, 04:23 PM
stainlesscycle's Avatar
usually hot seizes can't be fixed with fluid in cylinder...
go to kawaski.com
click on
owner info->parts diagram->kx100 (or whatever it is)->cylinder/piston
that'll show you what's going on in there, so you'll have an idea of the parts.
the process is the same for every water cooled 2 stroke.
drain radiator
remove head
remove cylinder base nuts
pull cylinder off (if pv you'll need to unhook first)
put rag in crankcase cylinder mouth
remove circlips from piston pin
push piston pin out (proper tool helps..but socket will work)
once it's apart you will need to check - piston, rings, cylinder,small end bearing, pin, and big end bearing play. you also need to clearance new piston, rings, etc. you will probably need a book to get specs for cylinder wear/etc. if you hot seized, you'll probably need a rebore/new piston/rings/pin/bearing and circlip. it's easier and harder than it looks to do it right
you may get away with just honing the cylinder (if the damage is MINIMAL - don't forget that piston slides up and down 10000 times a minute) but if it seized i would not reuse piston/rings/pin/bearing or circlips....
overall you're talking between $100 and $300 in parts i would think. rebores are cheap (usually $25ish). pistons are cheap for kx100 i would think (under $100)....
any competent motorcycle shop could do the job in 2 hours or so (minus the rebore).
07 ec300
www.stainlesscycle.com
Old 07-26-2010, 06:40 PM
dank's Avatar
thank you very much stainless. the guy who does my suspension work said he would be willing to help me out if i needed it so that came as a big relief. thanks for the run through, im going to start taking things apart in the next week so ill keep asking questions as the need arises. thanks all for the replies!
03 ec250
Old 07-27-2010, 01:59 PM
dank's Avatar
thank you very much
03 ec250
Need help learning to stand up!! skid jackson Riding Techniques & Training 56 02-28-2013 12:26 PM
Ready for the Weekend cladoo General Discussions & Announcements 0 05-20-2010 08:09 AM
Getting ready for a new gasser pbspecial General Discussions & Announcements 16 04-24-2010 06:08 AM
Need help learning to sit down! Magellan Riding Techniques & Training 24 05-09-2009 10:06 PM
My Gas Gas ready to go! cladoo Pictures & Videos 5 05-22-2007 06:09 AM
