Old 12-27-2016, 12:30 AM
savage sausage's Avatar
savage sausage savage sausage is offline
Default Led front headlight goes off when revved
Ive wired up a new led bulb directly to the reg/rec it powers on when idling with a slight flicker, but when the engine is put under load it goes out.
What have i wired up wrong
Old 12-27-2016, 01:39 AM
Try put a large capacitor as a faux battery, say 1000uf or ideally more and 25v rated. Or hook up to a battery to check. Regulation can go screwy if it sees an open.
Old 12-27-2016, 02:36 AM
Thanks for the reply
In short the 2 wires from external genetator are wired directly into a new Reg/Rec , and the headlight wired up directly to R/R (no switches wired in yet)
so where do i put the capacitor?
Old 12-27-2016, 04:37 AM
Leo's Avatar
Leo Leo is offline
after reg/rec
www.endurohp.eng.br
Sherco ST300 2015 (Trials)
https://www.instagram.com/leocm74/
Brasil!
Old 12-27-2016, 05:04 AM
Originally Posted by Leo View Post
after reg/rec
So that would be on the actual wire for the bulb +
correct?
Is a bigger uf capacitor better ? 2000/ 4000/ 10,000
buyong one is no problem just want to by the right one the 1st time
Old 12-27-2016, 01:30 PM
2200uf 25v will be fine, and what I've used in similar setups.. A 16v will be too close to the line but would be OK for a test. They will be polarised so + to + power.
Old 12-27-2016, 02:08 PM
forgive me for being stupid but is that 1 capicitor leg soldered on the reg/reg end and the other on the high beam of the bulb its self?
tell you what tommorow ill add some pictures so you or anyone else can see the setup, ive used bullet connectors
crimped and soldered them all.
on a side note i got the rear led brake to work off a 9v battery to test, but it only worked when the - was on the - part of the battery l, i assumed that it would just need grounding as is? but maybe it needs to be grounded to the input/output of the reg rec?
muck fe this electrical gubbins is harder than then carb adjusting or rebuilding a top end
Old 12-27-2016, 02:49 PM
pscook's Avatar
pscook pscook is offline
I have nothing to add except that a good friend always told me "just remember it's electrical theory."
I agree that sorting out the electrons is MUCH more difficult than anything mechanical. Good luck!
Phil
(New bike pending...)
Old 12-27-2016, 03:59 PM
Neil E. Neil E. is offline
Best to connect the capacitor across the rectifier output the same way a battery would be connected. Observe the correct polarity as F5 has mentioned.
Old 12-27-2016, 04:03 PM
on a side note i got the rear led brake to work off a 9v battery to test, but it only worked when the - was on the - part of the battery, i assumed that it would just need grounding as is? but maybe it needs to be grounded to the input/output of the reg rec?
Depends on how you wired the system. Assuming the output of the rectifier is ungrounded, plus goes to your brake switch and then to the plus of the light. Minus goes to the minus of the light.
FOR SALE, 250XC forks, NEW fender, front wheel, front wheel bearings iamyvr Parts 5 07-27-2014 08:18 AM
2011 Front Fender with 2010 Headlight Jakobi Enduro Chassis & Body 4 05-24-2013 11:55 AM
lights flickering and going off when revved Elliker Enduro Engine - 2 stroke 9 01-21-2009 05:28 PM
06 EC300 - strange sound when over revved colinmc400 Enduro Intake/Carburetion - 2 stroke 5 05-02-2008 12:10 PM
