Parts New/Used Components and All Bike Part Outs |
Last of my GasGas parts sale
2 sets of center cases- $200 for each set
2 crank shafts- $100 for each 2 Basket ring gears, on large bore one small $75 each 6 speed transmission, needs new counter shaft $150 Boyseen Reed cage $40 V force reed cage $45 Rear brake setup. Pedal, master, slave, carrier, $100 Rear brake parts. Master and slave bodies $40 Front brake setup. Master, slave, lever, line $100 Clutch cover $40 Bent radiators $20 2 rear axles with adjuster blocks $25 each Swingarm pivot bolt $20 2 power valve ball ramp assemblies $35 each Domino throttle housing shell $25 Fuel tank $30 2 swingarms with linkage and rocker $100 each 2 frames make offer coil $10 Last edited by PEB; 03-23-2018 at 03:31 PM. |
Parts are cross listed on a Facebook site
What year are the parts off?
All parts were from 2005 and 2007 bike
Coil and kickstand added
parts
I'll take the kickstand. PM sent.
Do you an air filter cage for a 01 200 ex?
No airfilter cage, sorry
Any kick starters?
No, buy the Yamaha part its an excellent kicker
2002 gasgas parts for sale | GAKLX | Parts | 9 | 08-14-2018 09:28 PM |
For sale gasgas parts | jorden199 | General Discussions & Announcements | 1 | 10-30-2012 02:24 PM |
